Thread: Audi 80 tdi juddering bucking jerking
Page 26 of 30 FirstFirst ... 162425262728 ... LastLast
Results 251 to 260 of 293
  1. Re: Audi 80 tdi juddering bucking jerking
    My '95 Audi 80 Avant TDI had quite severe jerking right on 3000 revs and gradually got worse dipping into the lower rev range. I could either drive through it or slack off to come out of it. Turned out to be a faulty microchip on an injector and I've haven't had any problems since. As far as I can remember, the cost was somewhere around £230-£240 with the injector making up the bulk of the cost. I think the injector was about £190 on exchange. One way or the other, I hope this helps.
  2. Re: Audi 80 tdi juddering bucking jerking
    Apr 2010
    I have had the same problem on my 80 TDi estate on a 95M. So far, I have changed the following;
    Timing belt, twice
    Fuel filter,
    Engine mounts
    Gearbox mounts,
    New glow plugs,
    used fuel pumps TWICE,
    New power steering rack,
    New camshaft pulley,
    New rear brake disc,
    Engine rebuild,
    Tried everything that other members have posted here, no joy and STILL the damn thing judders! This has has been a money pit from the day I bought it. I am guessing flywheel? I am determined to win this war, but the piggy bank is thinking otherwise. Has anyone got any ideas what it might be???
    Desperate now!
    Azim.
  3. Re: Audi 80 tdi juddering bucking jerking
    Aug 2007
    Midlands, Uk.
    The problem is most definately down to the injection pump and specifically iron particles building up inside. You need to desolder the pump connections to get to them.
    It is quite expensive to have re-built and there are several DIY articles regarding cleaning them out. I'll try and remember where they are, unless someone else can tell us quicker!!
    There is also the much easier mod of removing the VSS signal from the dash to the ECU if you need a quick fix.
  4. Re: Audi 80 tdi juddering bucking jerking
    lancashire
    I cut the blue and White wire and adjusted the actuator on the turbo and blanked the Egr valve sorted it but every now and then it used to hunt on idle but to be honest I was using 100 percent bio diesel . I wish I still had the 80 instead of an a3 pd
    Hope this helps good luck jay
    And it's true the swarf build up inside the pump is the problem from what I can understand the throtle arm moves on a brass plate a bit like a scalectrix controller if you see what I mean
  5. Re: Audi 80 tdi juddering bucking jerking
    Apr 2010
    Many thanks for your advice... I guess I will use my AA parts and labour policy to try and get this sorted out. I will keep you all posted no doubt because from what I see...260+ comments on this and no one is closer to a definite resolve. Everyoine seems to be trying different solutions which works for them.
    For me, a process of elimination has brought it down to either Pump, Injector or Flywheel(?)
    regards,
    Azim.
  6. Re: Audi 80 tdi juddering bucking jerking
    Aug 2007
    Midlands, Uk.
    Quote Originally Posted by azimnazir View Post
    regards,
    Azim.
    Have you tried removing fuse 12?? (I think its 12 for the dash). This stops the VSS signal getting to the ECU and disrupts the feedback loop causing the juddering. Obviously don't try permanently because you lose the speedo, but its quick way to check if you're onto the same problem. If this stops the problem, I'm 99.9% certain its the pump. I wish I could find the link to the webpage for clearing the pump.
  7. Re: Audi 80 tdi juddering bucking jerking
    Dec 2007
    8 Post(s)
    regards,
    Azim.
    The problem with the swarf in the fuel pump can be improved immensly by cleaning out and using compressed air to try to blow the swarf out.
    Your problem may be different as you have said that you have already changed two fuel pumps.
    It is unlikely that all were faulty, or at least there should have been some differences noted.
    Did you read fault codes.
    Number three injector can go faulty, but I think it should show as a fault.
    The fault with the swarf in the fuel pump in my case showed up as a violent jumping / jerking at abour 1500 revs but would dissappear
    after revs built up further, it could reappear in a milder form in high gear either while driving,again could be overcome by driving through
    the problem by higher revs. It could also happen while slowing down.
    I took my pump apart and cleaned it out, but I would not recommend it as it is very tedious and possibly unsafe.
    The simplest method is to clean it. I think it was Acmo who wrote an article after he cleaned his out, I did not see it as I think you had to apply by e mail for his instructions. You wil probably find it back in the earlier posts.
    Good luck with finding your problem
    Regards,
    Michael.
  8. Re: Audi 80 tdi juddering bucking jerking
    Aug 2010
    kigsbridge, devon
    This is what I put together after replacing my pump I thought I would investigate and sure enough like a few guys have said, its swarf.
    https://docs.google.com/viewer?a=v&p...thkey=CKPvnvgL
    Hope it helps
    Ben
  9. Re: Audi 80 tdi juddering bucking jerking
    Apr 2009
    ireland
    Hi Guys,
    That's the longest thread I've ever read!!!
    Just bought a 1994 80 avant last week. (220k miles) Was worried about the judder before I read this.
    Thanks guys
    I now know its not a major problem, just a "few" quid to fix. (or "a quick snip will do it" - now, where have I heard that before.....)
    So, this i what I need to check/do -
    1-No 3 injector replacement (I assume I'm better off replacing them all!! Correct?? )
    2- "swarf" in injector pump - clean out.
    3-Cut the dash wire (that's going to be fun - colour blind )
    I have access to a 93 avant that I can use for parts. I assume I can straight swap the injector?
    Great thread,
    Thanks,
    Arderra
  10. Re: Audi 80 tdi juddering bucking jerking
    Jun 2007
    Gwent
    I don't know what others think, but the way I read it, the inj pump swarf seems to be the most common issue. Unplugging the speed sensor or pulling the fuse for the instruments has the same effect as cutting the blue/white wire. If the car is improved and you are happy with the throttle response you could get away with cutting the blue/white wire.
    Doing this does not solve the problem, but it does mask the issue?
    The full pump repair appears fairly straightforward, but probably not for the faint hearted?
    The no.3 injector issue is another one that can cause running problems, but i think it will give a fault code? If you choose to change all injectors I would consider ones from the AFN 110 hp engine, you will get a bit more bang for your buck!
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Audi 80 tdi - juddering problem
    By Ed Ray in forum 80 - 90
    Last Post: 10-12-2015, 11:33 AM
  2. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  3. Audi A6 2.0 TDi 2005 'juddering' clutch
    By Mark Carter in forum Chat - Completely Off Topic
    Last Post: 12-01-2009, 11:05 PM
  4. vw golf cutting out/jerking problem
    By vwgirl in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-03-2007, 11:58 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
