Thread: vw golf cutting out/jerking problem
  1. vw golf cutting out/jerking problem
    Jun 2006
    my '96 2.0L 8v cabriolet intermitantly cuts outs, revs jump up and down causing jerking and backfiring . Also, strange clicking noise occurs around ignition switch/dashboard whilst this is happening.
    Throttle body was cleaned out year ago which resolved stalling at low revs. Mechanics computers says halls sensor fault, replaced distributor problem still occurring. Now says crank shaft sensor which will cost £200! Mechanic could be very wealthy before problem resolved!!
    Any help would be much appreciated, cheers you guys...
    Jul 2006
    I have a Mk 3 Golf GTI 16V, my car used to cut out for no reason, jerk etc. I have just changed the crank sensor, fault cured!
  3. Golf mk 3 cutting out
    Aug 2006
    Oxford
    Golf Mk 3, 1.6GLS, auto, 98,000miles
    Have just had crank sensor and coil replaced, but this has not cured problem.
    Car cuts out on warm up, maybe 70 - 80 deg, and then starts after 1 - 2 mins and runs fine all day when hot.
    Get HT spark when in "faulty" mode.
    No diagnostics reported at all. Regularly serviced.
    Any tips please?
    Tony
    Mar 2007
    Try doing a Google on part number 165906381 and you will see lots of Golf problems with this relay. It only costs £11 from the dealer.
  1. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  2. problem with Golf Clipper cutting out!
    By marty_dude in forum Golf MK2 - 1984 - 1992
    Last Post: 01-06-2007, 11:16 AM
  3. Starting/cutting Out Problem
    By MJB20V in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-02-2007, 01:41 PM
  4. help with cutting out problem
    By the blonde bombshell in forum Passat - Archive Topics
    Last Post: 17-09-2006, 10:36 PM
  5. Problem with Golf 1.6SE 2000 cutting out
    By Katherine in forum Archive posts
    Last Post: 24-05-2006, 02:27 PM
