Thread: Juddering C
  1. Juddering C
    Jan 2005
    Huddersfield
    I have a really bad running problem with my '90 1.8 16v Corrado. Every time i try to pull away from standing the car judders and nearly stalls like its running out of petrol.
    It only does this at low revs so i have to get the revs over 3500 just to get the car going. After 3.5K the car will run fun and pulls/drives very well.
    This has only started the last couple of days and i havent had time to check anything yet so im just looking for some tips on what it could be
    Thanks J
    Feb 2004
    Yorkshire
    49 Post(s)
    Sorry for the delay in the reply, been ill for almost 3 weeks and neglected my duties on the site
    It sounds as though you could have oil on the clutch from either a leaking rear main oil seal, or gearbox seal, I had this happen a long time ago, with similar symptoms.
    May also be worth a look at engine mounts as well, a worn mout may cause it.
    Hope this helps a bit, unless you have already sorted it.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
    Jan 2005
    Huddersfield
    Thanks Stuart Ive changed the clutch that was very worn and as I was doing that ive found that the front engine mount was completely shot !!!!!! You couldn’t tell from looking or rocking the engine but when you pull away the engine would move back by a good 8 inches
    So ive changed it for an uprated JMR one and everything is perfect again.
    Thanks Stuart
  1. Mk3 16v gti juddering/missfiring
    By rosser81 in forum Golf MK3 - 1993 - 1999
    Last Post: 10-11-2007, 07:36 PM
  2. juddering issue
    By carl_townshend in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2007, 09:04 PM
  3. mk3 golf gti juddering
    By chelski205 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-06-2007, 11:42 AM
  4. Engine Juddering / Too Hot
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2007, 02:09 PM
  5. Juddering S4
    By Lenny75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2007, 06:28 PM
