Thread: Rear brake discs. Audi A6 2006
Results 11 to 20 of 25
  1. Re: Rear brake discs. Audi A6 2006
    #11
    May 2013
    Barnstaple
    Yeah my fronts a brembo aswell mark. They're good discs however I get excessive squeeking from them. To be honest I think it's the pads. I have to clean the face of the pads on an almost weekly basis as it drives me mad.
  2. Re: Rear brake discs. Audi A6 2006
    #12
    Nov 2012
    Somerset UK
    Has to be the pads, had mine done 3 weeks/500 miles ago and not heard a peep from them thankfully!
  3. Re: Rear brake discs. Audi A6 2006
    #13
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Steve_K View Post
    Thanks mate.
    No worries ...
    Yeah Its weird how they're purely 5 holes on the front but 9 plus the Torx screw on the rear
    I agree ... I got no idea as well ...
    This is a general video but good for pointers/info...
    ATB
    G
  4. Re: Rear brake discs. Audi A6 2006
    #14
    Nov 2012
    Somerset UK
    Possibly a weight saving benefit, but more likely made for multiple applications
  5. Re: Rear brake discs. Audi A6 2006
    #15
    May 2013
    Barnstaple
    Yeah I think I'm going to have to change the front pads as I'm not going to be able to put up with the noise for much longer. Thanks for the video gupsterg. I've watched it a few times over the past few weeks. Just hopefully the battery charger will keep the system voltage up enough. Any idea what would happen if the system voltage fell too low? I'm assuming the EPB would fail. I've got VCDS and the genuine Ross-Tech cable. VCDS & Elsawin are by far the best buys for my audi that I've made. Bar the car itself of course
  6. Re: Rear brake discs. Audi A6 2006
    #16
    Sep 2011
    Quote Originally Posted by MarkTM View Post
    +1, on above ...
    I've used charger for MMI update & EPB on slave points under bonnet no issues, I did make sure all interior lighting was switched off via switch, fan blower on AC by holding down "ECON on/off" and turned off any other functions which I thought would be a drain ...
    This video helped me remove the front/rear discs as they were seized on...
  7. Re: Rear brake discs. Audi A6 2006
    #17
    Aug 2006
    Thessaloniki, Greece
    A bit off topic, just had my front discs/pads changed at 172.000 km.
    At what mileage do you change the back discs?
    2006 Audi A6 Allroad 3.0 TDI Tiptronic
  8. Re: Rear brake discs. Audi A6 2006
    #18
    May 2013
    Barnstaple
    To be honest mate it depends on the type of discs and pads you're using and how heavy you are on the brakes. On my rear discs the minimum thickness is 10mm. The best way to tell is to run your fingers across the surface of the disc and if there's a prominent ridge on the outer edge, it's most probably time to change them
    2 1 0
  9. Re: Rear brake discs. Audi A6 2006
    #19
    Aug 2006
    Thanks, that's what the AD said too. At which mileage did you have yours changed?
  10. Re: Rear brake discs. Audi A6 2006
    #20
    Nov 2012
    Somerset UK
    Quote Originally Posted by gianton View Post
    My discs were done just short of 90,000 miles (144,000m) Indy advised they (originals) still had another 20k miles left in them but better off/cheaper getting all 4 corners done at once Pads I'm sure don't last that long maybe every 30k miles/50k kilometers
  1. Rear Brake Discs
    By dickturpin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-06-2011, 07:20 PM
  2. Question Rear Brake discs
    By brollah in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2010, 09:52 PM
  3. Question Rear brake discs
    By mikegbingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2008, 03:26 PM
  4. Question Replacing rear brake discs T4
    By Dai Lampard in forum The Commercial Range
    Last Post: 20-07-2008, 09:31 PM
  5. Rear brake discs
    By dumpee in forum Audi A3 - Archive Topics
    Last Post: 06-02-2008, 02:28 PM
