Thread: Rear brake discs. Audi A6 2006
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Rear brake discs. Audi A6 2006
    May 2013
    Barnstaple
    Ive just ordered new rear discs for my A6. Ive checked my current discs and they're 5 studs. However they have 9 holes in, of which 4 are covered up. Ive ordered hole discs. Will these be ok? Thanks in advance
  2. Re: Rear brake discs. Audi A6 2006
    May 2009
    Stirling, Scotland
    Do you mean 9 holes round the hub of the disc I take it? Can't see an issue so long as the dimensions are matching the right audi ones and the 5 studs correctly line up. Where did you buy them from as this sounds more lkie a generic disc, although some manufacturers prob. do this all the time :-) Pretty sure my EbC discs only had the 5, plus the torx screw holethough you've got me wanting to check again now!
    p.s. I hope you've got a vcds cable! You'll need it to get the calipers unlocked and taken off :-)
  3. Re: Rear brake discs. Audi A6 2006
    May 2013
    Barnstaple
    Yeah 9 holes around the hub. Yeah ive got the genuine VCDS cable and software so that's not an issue. I got them off Euro car parts. They're half decent Bosch discs so hopefully they'll be fine. The dimensions of the disc various slightly from manufacturer to manufacturer but not a great deal
  4. Re: Rear brake discs. Audi A6 2006
    Sep 2011
    Lurking over a keyboard ...
    I can't comment on after market disc sizes but you can check your option codes for factory fit brake option by entering PR codes off data sticker in spare wheel well/service log ...
    Here is a link to a decoder, there is also a PDF on this webpage about the data sticker ... Link:- http://prsearch.planetvag.com/
  5. Re: Rear brake discs. Audi A6 2006
    May 2013
    Barnstaple
    Cheers gupsterg. Ive just double checked the diameter and thickness of the discs ive ordered against genuine parts and they're exactly the same. Just seemed weird how the genuine ones on the car at the minute had 9 holes in the hub, only 5 of which were fully drilled through. Where as the new ones have 9 holes and all 9 are drilled through. cant see it making any difference to be honest
  6. Re: Rear brake discs. Audi A6 2006
    Nov 2012
    Somerset UK
    What brand did you get?
  7. Re: Rear brake discs. Audi A6 2006
    May 2013
    Barnstaple
    They're Bosch discs. A few of the guys at work said they're reasonable discs.
  8. Re: Rear brake discs. Audi A6 2006
    Sep 2011
    Quote Originally Posted by Steve_K View Post
    I fitted Pagid pads & discs all round, mine a 3.0 TDi TIP Avant, PR codes for brakes 1LG Front & 1KD Rear ... done over 10K miles on them zero issues, same if not better performance as the genuine ones they replaced ...
    IIRC they had 9 holes and all drilled plus the 10th being the one for the torx screw to hold it to the hub, I will double check at some point, images for the discs on the web also show 9 holes ...
    Some posts that maybe useful info ...
    Quote Originally Posted by gupsterg View Post
    I found this on the net RE Tech data on braking system...
    Front brakes
    Manufacturer coding (PR No.) 1LT 1LD 1LG 1LH, 1ZL 1LJ
    Brake caliper FN-3 16" FNR G60 16" FNR G60 16" FNR G60 17" 2 FNR 42 AL 18"
    Ventilated brake disc Ø mm 314 321 321 347 385
    Brake disc, thickness mm 25 30 30 30 36
    Brake disc, wear limit mm 23 28 28 28 34
    Brake caliper, piston Ø mm 57 60 60 60 60
    Brake pad thickness mm 19.5 20.24 20.24 20.24 20.43
    Brake pad wear limit mm 3 4 4 4 4
    Rear brakes
    Manufacturer coding (PR No.) 1KD, 2ED 1KW, 2EE
    Brake caliper C41 (16") C43 (17")
    Brake disc Ø mm 302 330
    Brake disc, thickness mm 12 22
    Brake disc, wear limit mm 10 20
    Brake caliper, piston Ø mm 41 41
    Brake pad thickness mm 16.90 17.46
    Brake pad wear limit mm 3 3
    VCDS Link:- Audi A6 (4F) Parking Brake - Ross-Tech Wiki
    Link:- Pagid - Best Practice Link:- Cera-Tec vs Copper paste
  9. Re: Rear brake discs. Audi A6 2006
    May 2013
    Barnstaple
    Thanks mate. I did wonder as to why, whenever you type in your reg on a parts website, they show discs of seperate diameters and thickness for the same vehicle. If the disc is vented then its adds 10 mm onto the thickness. Wasn't sure if you'd need a slightly larger hub so just stuck with what I knew and ordered the 302 x 12 mm discs. Yeah Its weird how they're purely 5 holes on the front but 9 plus the Torx screw on the rear
  10. Re: Rear brake discs. Audi A6 2006
    Nov 2012
    Somerset UK
    My discs were Brembo and pads Jurid, which my indy assured me were as good if not better than OEM in terms wear/progressiveness/longevity
  1. Rear Brake Discs
    By dickturpin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-06-2011, 07:20 PM
  2. Question Rear Brake discs
    By brollah in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-04-2010, 09:52 PM
  3. Question Rear brake discs
    By mikegbingham in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2008, 03:26 PM
  4. Question Replacing rear brake discs T4
    By Dai Lampard in forum The Commercial Range
    Last Post: 20-07-2008, 09:31 PM
  5. Rear brake discs
    By dumpee in forum Audi A3 - Archive Topics
    Last Post: 06-02-2008, 02:28 PM
