To be honest mate it depends on the type of discs and pads you're using and how heavy you are on the brakes. On my rear discs the minimum thickness is 10mm. The best way to tell is to run your fingers across the surface of the disc and if there's a prominent ridge on the outer edge, it's most probably time to change them
