Thread: Issues after egr delete
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Issues after egr delete
    Oct 2012
    shoreham by sea
    After egr delete my running temps r not going over or barley 70. Thrash it up a hill in gets to 90 but cruising brings it below 70.
    on filling tank mileage b4 always crept up. Yesterday was 1st fill up,£60 showed 460,after driving 20 miles usually the gauge creeps up,so from 460 and 20 miles later its down to 380!
    heater seems ok. 25deg seems warm and hi seems hotish.
    fuel gauge seems on par with display, running to quick?
    any ideas, someone suggested small hole in blank, at this rate think il convert back to normal.
    does seen more responsive and smoother though since blank.
  2. Re: Issues after egr delete
    Southern County Softy
    20 Post(s)
    Failed thermostat, nothing to do with the EGR delete.
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  3. Re: Issues after egr delete
    Oct 2012
    shoreham by sea
    Ok,this is an easy cheap fix I believe?
    thought the egr helped warm up the engine,takes forever to get to 70,like 15-20 mins at cruising.
    so a new thermo will sort out all the above? Rough price n time please gents?
  4. Re: Issues after egr delete
    Aug 2011
    Hornchurch
    Quote Originally Posted by deano1978 View Post
    If it's anything like the 1.8T It is £80 for the stat and housing, and is quite involved to fix, not something recommended to a novice mechanic. (not saying you're a novice )
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  5. Re: Issues after egr delete
    london/ UK
    What engine do you have ? If it's a 1.9 Tdi then it's easy, if a v6 then it's behind the cambelt- sadly not a easy job to do !
  6. Re: Issues after egr delete
    132 Post(s)
    1979 Post(s)
    Actually the action of EGR is to lower combustion chamber temperatures to reduce the levels of NOX emissions.
  7. Re: Issues after egr delete
    Oct 2012
    shoreham by sea
    Ok so I've drilled a hole in my blank plate as som1 suggested this will remove the light.
    no joy?
    even if I go back to normal, do I still need fault cleared?
    if it ain't broke don't fix it!!!
  8. Re: Issues after egr delete
    132 Post(s)
    1979 Post(s)
    You will have to clear the code.
  9. Re: Issues after egr delete
    Oct 2012
    shoreham by sea
    Ok,thanks for that.
  10. Re: Issues after egr delete
    Oct 2012
    shoreham by sea
    no joy?
    Went garage,cleared code,5miles later back on?
    Shld the vacuum be connected back up too?
  1. Anyone tried EGR delete kits?
    By Turbokiisseli in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-11-2016, 11:57 PM
  2. DPF delete + EGR
    By spazmatron in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-11-2012, 12:37 AM
  3. Decat and EGR delete
    By Peter_HMR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2011, 09:41 PM
  4. EGR delete
    Last Post: 29-03-2011, 09:58 AM
  5. egr delete ???????
    By PAT_GT_TDI in forum Golf MK4 - 1999 - 2004
    Last Post: 13-01-2010, 05:13 PM
