Thread: Anyone tried EGR delete kits?
Results 1 to 10 of 13
  1. Anyone tried EGR delete kits?
    May 2008
    Finland
    Hey all!
    Has anyone tried an EGR Delete kit? http://www.egrvalve.co.uk/ sells them, for example.
    They only list it for the Golf PD engines, but I asked and they say their kit will also fit my B6 with the AWX engine.
    Any experiences?
    ____________________________________________
    VW Golf Mk.V 2.0tdi 4Motion
    VW Golf Mk.IV 1.4i
  2. Re: Anyone tried EGR delete kits?
    Sep 2007
    Essex boy in Suffolk
    I've been thinking about fitting one of these aswell, I've read comflickting stories on wheather you have to update the ECU software when this is done otherwise you may get a warning light on the dash.
    I've disconnected the vacuum pipe to the valve and it seems to have improved the bottom end a little (although that could be my mind playing tricks wanting it to be better)
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  3. Re: Anyone tried EGR delete kits?
    durham
    hi i put a blank plate on exhaust end of connecting pipe on manifold and left everything else connected and is fie ecu thinks all is ok but no horrible exhaust gasses getting into inlet manifold
  4. Re: Anyone tried EGR delete kits?
    Mar 2007
    Lancashire
    All seems well and good but think why they are there? They do prevent alot on Nitrous oxide gases polluting the atmostphere. I have tried a few things, I even had the pipe off. It reduced the smoke but performance gains were in my head... I tested it with VCDS logs.
    When under acceleration the EGR as good as shuts and only uses EGR when idle or very little power required. I'd go for a remap which does use less EGR than normal or use VCDS to minimise EGR usage but not completely stopping it functionality.
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  5. Re: Anyone tried EGR delete kits?
    Nov 2008
    N/A
    Quote Originally Posted by Borab0y View Post
    I've adjusted it to minimum using VCDS.
    I think you're thinking about MkIV's - pre-2003 don't have a problem. Some 2003 on do. All the B6's throw a CEL light I think.
  6. Re: Anyone tried EGR delete kits?
    May 2008
    Finland
    benjie,
    How did you adjust the EGR? I didn't think it was possible on a B6 like it is on the older distributor pump equipped tdis.
    As for the EGR and the atmosphere, I know it's there to cut down NOX emissions, but I think the gain is not worth the trouble these things can cause and the cost that can be involved in changing them.
    VW Golf Mk.IV 1.4i
  7. Re: Anyone tried EGR delete kits?
    Mar 2007
    Lancashire
    It is possible and works well. If you look at www.ross-tech.com there is information about the adjustment. I have a word document at home that I can send if you like? It contains what to do. If you have a registered version of VCDS then you can monitor EGR usage whilst the engine is running. I think this is a more sensible option to deleting the EGR completely.
    Re-map by more-bhp.
  8. Re: Anyone tried EGR delete kits?
    Nov 2008
    N/A
    You do it in the same way that they say on the ross-tech site, http://www.ross-tech.com/vag-com/cars/tdi.html - towards the bottom. Even though it says it doesn't work for PD engines, someone else on this forum pointed me in the direction of an article which says that since vag-com has been updated, it is possible now- using the same procedure. Though I can't for the life of me remember where it is!
    Marco, can you send me the document please? I want to be 100% sure I'm correct.
  9. Re: Anyone tried EGR delete kits?
    Dec 2004
    Derbyshire
    I've got 2003 A6 1.9TDI 130 (AWX), a while ago mine developed hesitation around 1600 to 1800 rpm at light throttle, so I disconnected and plugged the vacuum line to the EGR and it cured the fault. It does not throw up any warning lights or fault codes.
  10. Re: Anyone tried EGR delete kits?
    May 2015
    Washington UK
    My car is leaking from the egr cooler can it be left on with a blank stopping it getting any exhaust fumes through without the eml coming on?
  1. 2.0 TDI EGR advice
    By corinb in forum Golf MK5 - 2004 - 2009
    Last Post: 07-12-2015, 11:46 AM
  2. Egr Valve - Low Flow, 1.4 Petrol
    By oceanicgreen in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2009, 07:26 PM
  3. EGR and turbo gurus, please help
    By Marco34 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-05-2008, 02:18 PM
  4. EGR Disconnected and constant whine!
    Last Post: 12-01-2008, 01:10 AM
  5. Cleaning the Intake Manifold....
    By Eshrules in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-04-2007, 07:51 PM
