Thread: Lacquer blistering on paint work!!
Results 11 to 20 of 36
  1. Re: Lacquer blistering on paint work!!
    #11
    Highlands
    12 Post(s)
    Hi Stuart
    I have known of the car from new and it has had no paintwork and the peeling is randomly all over it . Also the internal switches peeling seems to be quite a common complaint on the B6 amongst this forums members. This is my third audi and I would have to say in my experience the finishing quality is not there on the B6 compared to my old B5
    Vin
  2. Re: Lacquer blistering on paint work!!
    #12
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I see ,then armed with that info it might be worth a trip to Audi but don't hold your breath
    Good luck
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  3. Re: Lacquer blistering on paint work!!
    #13
    Aug 2008
    I have a 2002 A4 in red, bonnet & roof are peeling badly.Will have to sand off all laquer & Re-base & laquer.It is all original paint so must be down to manufacture error.
  4. Re: Lacquer blistering on paint work!!
    #14
    Feb 2009
    Right - got no luck with the dealer as expected they put it down to stone chips. So took it to Chips away. They wanted lots of money to strip the paintwork right back, respray it and then re lacquer it. I haven't got the money nor can justify getting this done.
    So I decided to research the Net and this problem appears to affect other cars and the advice was all the same - Respray whole panels for a proper fix. What the bloke at Chips away recommended though was to remove the flaking laquer using a scotchbrite cloth or similar. I used Halfords paint removing sponges (come as a set of 3 designed for removing flaking paint). You then need to smooth the edges using 1500grit wet and dry paper. It's recommended that the paper is very wet and you use washing up liquid in the water to lubricate it.
    Once the area is smooth then mask it all off, allowing space for overspray on the surrounding area of the damage and spray it with 3-4 coats of clear lacquer from a can, again purchased from Halfords. Once it's been sprayed you then leave it 2 weeks or so to go hard and blend it in using a rubbing compound.
    Well I've just done this and it worked an absolute treat. You can still see the areas of repair (but only if you look closely) but it is far better than seeing great flakes of lacquer missing. It also seals it so no more will peel off from it.
    It was very easy to do this but just go careful on spraying the lacquer. The key is not to rush any stage of it. I'd definitly recommend giving it a go especially as the products cost be about £20 in total which is much better than £90 per panel!!!!!
  5. Re: Lacquer blistering on paint work!!
    #15
    Tullamore, Ireland
    I have a small spot of corrossion on my bonnet where a stone has completely chipped away the paint. This would hardly be covered under warrenty would it?
  6. Re: Lacquer blistering on paint work!!
    #16
    To properly rectify the paint defects the panels will need to be re- basecoated and lacquered , not good i know and wont be cheap either for a professional job as your audi deserves.
    personally i wouldnt deal with chips away or other smart repair companies the repairs they do never stand up to the long term weather , usually a quick fix to sell the car etc
  7. Re: Lacquer blistering on paint work!!
    #17
    Mar 2009
    Hi guys, I have a 2002 A4 TDI amulet red and the same is happening, serious peeling happening on the bonnet, and a couple of small spots on the roof, apparently where stones have hit but not really chipped the paint. Seems to me the lacquer is not sticking properly. Have read a few other forums and it looks like it's a particular feature of this paint colour. Not sure I can face another humiliating trip to the dealer as the car is 8 years old....
  8. Re: Lacquer blistering on paint work!!
    #18
    6 Post(s)
    Quote Originally Posted by tbass View Post
    Definately seems to be an issue now they've switched to water-based paints. Once the lacquer seal is damaged, water and heat will do the necessary damage and it becomes unsightly.
    Only professional long-term repair is to completely repaint the car, however this isn't really an option on older cars.
    My mint 1995 80 Avant TDi was metallic green. Even with stone-chips the paint lacquer never lifted. Compare that to my B5 Audi A4 Quattro Avant which had lacquer damage before I bought it. Audi repaired it under warranty. Now just have a little damage on the bumper - which I can live with. Sanding the edges back with wet and dry paper and relacquering is a cost-effective fix on cars over 6 years old.
    2017 A4 Allroad Quattro Sport 3.0 TDI 272PS, (59k)
    2016 BMW i3 REx (80k)
  9. Re: Lacquer blistering on paint work!!
    #19
    Dec 2007
    Coventry
    Guys this problem isn't confined to older cars either as mine is a 2008 A3 and the lacquer is starting to peal on the front bumper. Took it to the main dealer and they told me it wouldn't be covered under warranty as it was down to stone chips - so how come the same problem doesn't appear on the bonnet where there are far more !?
    I'm no expert but I know the bumpers and body are not painted in the same factory but I would expect them to be finished to the same standard and not blister in such a short time.
    Any advice onn how to get this sorted would be appreciated as I need to hand the car back in the next 6 months and do not want to be hit with costs for this :-/
  10. Re: Lacquer blistering on paint work!!
    #20
    6 Post(s)
    Quote Originally Posted by campaxton View Post
    I'm assuming you have the car on a fixed-term loan with the option to buy? Normally these sort of agreements limit your mileage, in the region of 8k per annum over 4 years. I'd put this down to wear and tear. There is no quick fix. The only way to sort is to flatten the blistered edges with a very fine grade wet and dry paper, then respray the whole panel with lacquer. Leave it alone and cross that bridge, if and when it happens.
  1. Intermitent wipers/indicators/heater fan don't work (1996 1.8 petrol)
    By stewburt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2009, 03:35 PM
  2. Please Help golf mk4 electric window,central locking,interior lights dont work?!
    By jody391 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2009, 05:18 PM
  3. How important is work to you?
    By Lis in forum Chat - Completely Off Topic
    Last Post: 08-07-2009, 01:03 PM
  4. Marked Paint
    By VictorPapa in forum Golf MK6 - 2009 - 2013
    Last Post: 23-05-2009, 11:31 PM
  5. Servicing and warranty
    By alanstead in forum Scirocco - 2008-
    Last Post: 11-05-2009, 08:28 AM
