Thread: Lacquer blistering on paint work!!
Results 1 to 10 of 36
  1. Lacquer blistering on paint work!!
    Feb 2009
    THe paint lacquer on my 2002 A4 Avant is blistering and coming off in places. First off there was only a few small patches which I could live with, but now there are more places on the car getting worse. I guess with the cold weather we have had it's made the lacquer blister but it's quite unslightly.
    I spend a lot of time detailing my car so it always has a good high polish and wax on it all year round. It is also a red car so this is especially important.
    Has anybody suffered with this. I know the car has definitly never been painted and it can't just be stone chips as there is some peeling on a passenger door and the roof near to the boot.
    Any suggestions to what I can do. It's going to be quite expensive I can imagine to get the car re-lacquered
  2. Re: Lacquer blistering on paint work!!
    Dec 2009
    west yorkshire uk
    hi mate
    ive also got some lacquer coming off on my audi tdi quattro sport. just on the front bumper and abit on bonnet? what u think would we have to get it all paint or can we just get lacquer done?
  3. Re: Lacquer blistering on paint work!!
    Southern County Softy
    20 Post(s)
    Is there a 10 or 12 yr warranty on paint ?
    Might be worth a call to the dealer
    A4 2.5 tdi QS (mapped)
  4. Re: Lacquer blistering on paint work!!
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    I`m sure its only 3 years for a paint defect,12 for rust through.
    Alan.
    VW T6 150 DSG Camper £££
  5. Re: Lacquer blistering on paint work!!
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Yes and then the dealer will give you the old,..."how can we be sure the car has not been badly repaired after an accident?" cobblers line ",it surely can't be a manufacturers fault".
    Been there
    Stuart
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  6. Re: Lacquer blistering on paint work!!
    20 Post(s)
    Quote Originally Posted by fourringsrus View Post
    Been there
    Stuart
    That line must be in a handbook somewhere......
  7. Re: Lacquer blistering on paint work!!
    Nov 2008
    20 Post(s)
    Been there
    Stuart
    They can check by measuring the Depth of the paint.They did it with mine on a very small mior rusting of bottom edge of rear door.They actually went ALL over 1 side of the car! Anything to try and say its been previously repaired!! It hadn`t though!
    Alan.
  8. Re: Lacquer blistering on paint work!!
    Feb 2009
    Right - got no luck with the dealer as expected they put it down to stone chips. So took it to Chips away. They wanted lots of money to strip the paintwork right back, respray it and then re lacquer it. I haven't got the money nor can justify getting this done.
    So I decided to research the Net and this problem appears to affect other cars and the advice was all the same - Respray whole panels for a proper fix. What the bloke at Chips away recommended though was to remove the flaking laquer using a scotchbrite cloth or similar. I used Halfords paint removing sponges (come as a set of 3 designed for removing flaking paint). You then need to smooth the edges using 1500grit wet and dry paper. It's recommended that the paper is very wet and you use washing up liquid in the water to lubricate it.
    Once the area is smooth then mask it all off, allowing space for overspray on the surrounding area of the damage and spray it with 3-4 coats of clear lacquer from a can, again purchased from Halfords. Once it's been sprayed you then leave it 2 weeks or so to go hard and blend it in using a rubbing compound.
    Well I've just done this and it worked an absolute treat. You can still see the areas of repair (but only if you look closely) but it is far better than seeing great flakes of lacquer missing. It also seals it so no more will peel off from it.
    It was very easy to do this but just go careful on spraying the lacquer. The key is not to rush any stage of it. I'd definitly recommend giving it a go especially as the products cost be about £20 in total which is much better than £90 per panel!!!!!
  9. Re: Lacquer blistering on paint work!!
    Nov 2010
    yateley hampshire
    Quote Originally Posted by alphamike583 View Post
    are you sure its the lacquer.My A4 is blistering along the roof channels.Am in process of gett ing repaired under 12 year anti perforation warrantyHave only been offered 70% of cost so far. I dont hold out much hope to get full cost covered
  10. Re: Lacquer blistering on paint work!!
    Highlands
    12 Post(s)
    I have spoken with a local paint shop who have quoted £600.00 to paint affected panels but I am reluctant as if the old lacquer is not totally removed from the car surely it will eventually start peeling of the panels not yet affected and possibly lift the paint in the newly painted areas if the lacquer has been painted over
  1. Intermitent wipers/indicators/heater fan don't work (1996 1.8 petrol)
    By stewburt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2009, 03:35 PM
  2. Please Help golf mk4 electric window,central locking,interior lights dont work?!
    By jody391 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2009, 05:18 PM
  3. How important is work to you?
    By Lis in forum Chat - Completely Off Topic
    Last Post: 08-07-2009, 01:03 PM
  4. Marked Paint
    By VictorPapa in forum Golf MK6 - 2009 - 2013
    Last Post: 23-05-2009, 11:31 PM
  5. Servicing and warranty
    By alanstead in forum Scirocco - 2008-
    Last Post: 11-05-2009, 08:28 AM
