Thread: Glow Plugs
Results 1 to 10 of 19
  1. Glow Plugs
    Mar 2010
    Belfast
    Could someone please tell me where I can the glow plugs on the B6 passat. They seem to be a well kept secret.
    Many thanks.
    Ps: Its an 06 2.0 Tdi
  2. Re: Glow Plugs
    Apr 2007
    France
    12 Post(s)
    Have you removed the plastic engine cover yet?
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  3. Re: Glow Plugs
    Mar 2010
    Belfast
    Quote Originally Posted by Quatrelle View Post
    Had the cover off several times, been in and around the engine with a mirror and could see nothing.
  4. Re: Glow Plugs
    Sep 2009
    Bournemouth
    I think they are under the plastic cover (held down by a series of screws) which is under the big clip-on cover over the engine. I will find out tomorrow because my CAG COM tells me I have an electrical fault with one of the glow-plugs (and an injector regulation range exceeded).
  5. Re: Glow Plugs
    Mar 2010
    Belfast
    Quote Originally Posted by billcoleman View Post
    Thanks for the reply mate, The bad news is that I just found out where they are and its not good for all those with 2.0 engines. Apparently they are located inside the rocker cover, under the rocker shaft. VW garage quoted £220 to replace the set, local guy going to do them for 120. Never thought a simple job like changing a set of glow plugs could be so difficult. They certainly did not make this engines easy to work on.
  6. Re: Glow Plugs
    Sep 2009
    Bournemouth
    Hi. Today I had the time to look at my glow plugs. You are correct - the plastic cover is the rocker/cam cover and the glowplugs along with all the wires and injectors are buried under the camshafts and all soaked in oil.
    The hardest part of the job was to remove the cam cover as it is surrounded by a bunch of pipes and the inlet ducting - so you need to remove the inlet elbow between the air filter and rear section, then you can remove the hidden bolt which retains the rear section.
    Now that you have some room, the cover comes off quite easilly.
    I then pulled-off cyl 4 glow plug elect cap (you need a pair of long nosed pliers) and checked the resistance from the connection to ground - it was open circuit - all the others were about 0.6 ohm.
    To remove the plug was fairly simple with an 8mm deep socket (in fact I have a set of T-sockets which is even better).
    I have a complete new set comming tomorrow from Eurocarparts and do not expect to take longer than 1 hour to get it all back together (may as well replace them all now).
    I agree it is all very complex, but not too bad once you locate all the bits.
    Price of the parts is about £55 delivered. All in all, much easier than the cam-belt change that I just did.
  7. Re: Glow Plugs
    Mar 2010
    Belfast
    Good job mate, I wish I was in a position to do my own, unfortunately I live in an apartment with no place to work at the car. It's a bit annoying having to rely on garages, especially at the rates being charged these days. What did it cost you for the cam belt kit?
  8. Re: Glow Plugs
    Sep 2009
    Bournemouth
    The belt kit was about £125 and water pump about £25. Locking tool set £25. Total with tools £175.
    I was quoted £500 by VW garage to do the belt plus another £150 to change pump at the same time. The pump is only held on by 3 bolts and took about 10 minutes to change (once the belt is removed).
    So I did a complete service at the same time (all filters and oil) - this all cost in total less than £250 which would have been around £1000 at the VW garage.
    So I then bought a VAG COM kit - that allowed me to diagnose the glow plug problem (and I now know that there is an injector out of range, but I do'nt know what to do about that yet).
    So far a pretty expensive car to maintain even if I do the work. It also seems to burn more oil than I was expecting.
  9. Re: Glow Plugs
    Mar 2010
    Belfast
    I find it a bit ironic that I decided on this car because I expected it to be economic to run, certainly got that wrong.
    Thanks for the info, cheapest where I live is about £175 for the kit, not enough competition. The plan these days seems to be to prevent one from doing their own work, to the extent they will not even provide technical information. Any chance they do a postal service where you got your belt kit? VAG COM kit would be another useful item.
  10. Re: Glow Plugs
    Sep 2009
    Bournemouth
  1. A3 glow plugs
    By harryscabvw in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-01-2010, 06:51 PM
  2. A4 1997 tdi no power to glow plugs
    By fastrac in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2009, 10:53 PM
  3. How to change Glow Plugs 2.0 TDI Sport BKD
    By jennion in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-08-2009, 02:11 PM
  4. Please Help Golf MK 2 1.6 Turbo Diesel glow plugs not working
    By mikehh in forum Golf MK2 - 1984 - 1992
    Last Post: 02-08-2009, 09:33 PM
  5. Glow Plugs
    By tsunami in forum Golf MK4 - 1999 - 2004
    Last Post: 03-03-2008, 07:42 PM
