Hi there have just found out fault code 17056 is a glow plug fault how hard is it to change the glow plugs on the 2.0 TDI.I understand they are under the rocker cover. I have changed glow plugs on the old 1.9 tdi engine before.cheers.
I also have fault code 16618 boost pressure exceeded what is the common cause for this fault ?
This last fault caused the car to go into limp mode. thanks for any ideas,suggestions.
