Thread: Help with identifying part
Results 1 to 10 of 11
  1. Help with identifying part
    May 2009
    dublin
    Hello there,
    Can someone help me identify part in picture and suggest remedy!!
    The engine cover on my 01 passat tdi came loose and from vibration and friction sheared a hole in the bend pictured.so im leaking deisel. is it the case that i can just replace the bend thats damaged or is the whole unit buggered??
    While im here i may as well ask if anyone knows where i could pick up a replacement engine cover?
  2. Re: Help with identifying part
    Feb 2004
    Yorkshire
    49 Post(s)
    Can you give me the part number off the label? or what looks like a part number from the picture...
    I will then see if I can find what it is.
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  3. Re: Help with identifying part
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by devereux View Post
    Hello there,
    The engine cover on my 01 Passat tdi came loose and from vibration and friction sheared a hole in the bend pictured.so I'm leaking diesel. is it the case that I can just replace the bend that's damaged or is the whole unit buggered??
    While I'm here I may as well ask if anyone knows where I could pick up a replacement engine cover?
    Unless I'm very much mistaken, that's the union to the fuel filter, whether you can pick the union up separately I don't know.
    Engine covers, probably a scrappers is the best bet.
    HTH
    Nothing to see here, move along..
  4. Re: Help with identifying part
    May 2009
    dublin
    cheers Stuart ,
    in work at the moment but will post the number on the label this evening
  5. Re: Help with identifying part
    Jun 2007
    Co Durham
    Hello there,
    I believe that is a fuel cooler. I looked at mine, it appears that the pipe is welded to it. It may be possible to braze or solder the pipe to repair the hole.
  6. Re: Help with identifying part
    May 2009
    Hello, it's the bend thats attached to the fuel filter. Filter is about £23 from main dealer. For the engine cover iv'e seen them on ebay.
  7. Re: Help with identifying part
    Jun 2007
    Co Durham
    Quote Originally Posted by saintsman View Post
    It's not the fuel filter! The part in the photo is attached to the filter by the bolt in the centre. The filter itself has no pipes attached to it!
  8. Re: Help with identifying part
    2022 Post(s)
    As stonedagain says, that is the fuel cooler heat exchanger.
  9. Re: Help with identifying part
    May 2009
    dublin
    Quote Originally Posted by stuart View Post
    The part number is 3B0 201 896
    Thanks to all
  10. Re: Help with identifying part
    2022 Post(s)
    3B0 201 896 is not available as a spare part, you have to buy assembly 3B0 127 400 C which is £160.
  1. Missing part - audi says part of design
    By psyho in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-07-2009, 01:50 PM
  2. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
