Thread: Check my scan
Results 1 to 8 of 8
  1. Check my scan
    Southern County Softy
    20 Post(s)
    A scan of my daughters A3 shows a few faults.
    Disregard the brake one, bulb changed and fault cleared.
    The scan shows a nav fault but can't find the number on the ross tech wiki.
    Also shows a phone fault but the car does not have phone prep.
    Oh the nav was a retrofit and i think the coding is correct.
    Thursday,07,May,2009,11:49:40:02168
    VCDS Version: Release 805.3
    Data version: 20090213
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 7D
    VIN: WAUZZZ8P84A063394 Mileage: 92300km/57352miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5705
    Revision: 12345678 Serial number: AUX7Z0C7FNK09X
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 D
    Component: ESP FRONT MK60 0102
    Coding: 0055942
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
    Component: KlimavollautomatH11 0130
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H29 0501
    Revision: 00029000 Serial number: 00000000137747
    Coding: 05884F00A2141000000000000000000000
    Part No: 8P2 955 119 A
    Component: Wischer WWS Audi350 0170
    Coding: 16711696
    Shop #: WSC 00000
    1 Fault Found:
    00988 - Lamp for Brake Light; Right (M10)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0011602
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 009 0030
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
    Component: KOMBIINSTR. VDO H25 0080
    Revision: D06 Serial number: 2247CD06000503
    Coding: 0004403
    Shop #: WSC 00763 210 52655
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Revision: 08 Serial number: 2400103724B78C
    Coding: 3D0F0B48070101
    Shop #: WSC 00185 210 89734
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D06 Serial number: AUX7Z0C7FNK09X
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 A HW: 8P0 035 192 A
    Component: RNS-E HIGH EU H70 0650
    Revision: 00S Serial number: AUZBZ0E0900003
    Coding: 0209711
    2 Faults Found:
    16352 - Control Module - Electrical Error
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 8875 km
    Time Indication: 0
    Date: 2006.04.08
    Time: 13:08:01
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 86945 km
    Time Indication: 0
    Date: 2008.08.02
    Time: 16:26:02
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000056
    Shop #: WSC 00185 210 80347
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 143 L
    Component: EPS_ZFLS Kl.7 0402
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 198800186D28050F485AC63000
    Shop #: WSC 00185 210 11803
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H02 0010
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 A
    Coding: 0000120
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209711
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 8875 km
    Time Indication: 0
    Date: 2006.04.08
    Time: 13:08:01
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 228
    Mileage: 86945 km
    Time Indication: 0
    Date: 2008.08.02
    Time: 16:26:02
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
    Component: PTC-Element 0404
    Revision: 00600000 Serial number:
    End
    A4 2.5 tdi QS (mapped)
  2. Re: Check my scan
    May 2007
    knee deep in clunge
    14 Post(s)
    change radio/nav code from Coding: 0209711
    to 0205111
  3. Re: Check my scan
    20 Post(s)
    Sorry forgot say she has BOSE.
    So it is a coding issue then.
  4. Re: Check my scan
    May 2007
    knee deep in clunge
    14 Post(s)
    0209111 with bose without phone
  5. Re: Check my scan
    20 Post(s)
    Thanks, I'll change the coding...
  6. Re: Check my scan
    20 Post(s)
    Coding changed, No fault on the phone unit.
    The scan still shows a fault an the nav and radio but can't find the number on the WIKI
    37-Navigation -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Coding: 0000072
    Readiness: 0 0 1 1 1
    Coding: 0055942
    Coding: 16711696
    Shop #: WSC 00000
    Coding: 0011602
    Coding: 0000012
    Coding: 0004403
    Coding: 0209111
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 8875 km
    Time Indication: 0
    Date: 2006.04.08
    Time: 13:08:01
    Coding: 0000056
    Coding: 0000120
    Coding: 0209111
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 8875 km
    Time Indication: 0
    Date: 2006.04.08
    Time: 13:08:01
    End
  7. Re: Check my scan
    May 2007
    knee deep in clunge
    14 Post(s)
    this normally means the cd drive is faulty but i would ignore if its working and try not to use the cd drive other than for the sat nav disc and see how you go
    Coding: 0209111
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 151
    Mileage: 8875 km
    Time Indication: 0
    Date: 2006.04.08
    Time: 13:08:01
  8. Re: Check my scan
    20 Post(s)
    Thanks, daughter prefers her music, if you can call it that, on SD card.
    The drive is used just for the nav disc.
  1. "How To" The FAQ & How To Thread
    By Ben in forum General
  2. Bora 2.0i Service Schedule Missing
    By zimbora in forum Bora - 1998 - 2005
    Last Post: 10-04-2008, 11:45 PM
  3. Service Checklist
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2008, 01:41 PM
  4. oozes class apparently...
    By dansansome in forum Chat - Anything with wheels
    Last Post: 14-03-2008, 11:38 AM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
