Thread: DIS AND CRUISE RETRO FIT b6+b7
Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 159
  1. Re: DIS AND CRUISE RETRO FIT b6+b7
    #41
    May 2007
    knee deep in clunge
    14 Post(s)
    No problem Shark you wont upset me I am very open and interested in all things AUDI
    vag diagnostics, retrofits and general repairs
  2. Re: DIS AND CRUISE RETRO FIT b6+b7
    #42
    Jan 2008
    Mansfield, UK
    Yep that's me over on Tyresmoke. Seems like an age away and I've lost count of the cars I've had since I sold the A4. Wish I never had
  3. Re: DIS AND CRUISE RETRO FIT b6+b7
    #43
    dovski Guest
    Ok you two, back on topic..
    why cant I log into abs to reset steering angle sense, there is no login option on 03 with vag-com or the (beta either-hex-can intfce).
    Fitted a suffix N swcm and DIS operates, but now flashing TPM warn light(not fitted) and ESP light on steady..***??
  4. Re: DIS AND CRUISE RETRO FIT b6+b7
    #44
    Dec 2007
    Quote Originally Posted by dovski View Post
    cant help with the abs or esp i just reset mine when i fitted
    but that TPMS light i got and no way could i get it off audi couldnt i recoded etc just wound not come off had dash checked nothing wrong with it put old scsm on and it went off fitted 3 diff scsm;s all did the same so i got dash man to sort it no TPMS light comes on and never will again
  5. Re: DIS AND CRUISE RETRO FIT b6+b7
    #45
    May 2007
    knee deep in clunge
    14 Post(s)
    go to address 03 then go to function 11 login and enter the code to reset the steering angle then clear all fault codes in address 01,03 and 16 and cycle the ignition and that's it check which version abs you have fitted but its the same method for bosch 8 and 5.7
    http://wiki.ross-tech.com/index.php/...#Basic_Setting
    post all code changes and original codes
    If you are using second hand steering column control units relearn the vin number address 16 Channel 081: Vehicle Data Learning
    To start the process for vehicle data (VIN) learning, enter/save 00111 as new value.
    Basic Setting
    Steering Angle Sensor (G85) Calibration
    [Select]
    [03 - ABS Brakes]
    [Fault Codes - 02]
    [Done, Go Back]
    Turn steering wheel at least 30 ° left and back straight ahead.
    [Meas. Blocks - 08]
    Group 005 Field 1 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±5.0 °
    [Done, Go Back]
    [Login - 11]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    All fault codes should have disappeared.
    [Done, Go Back]
    [Close Controller, Go Back - 06
  6. Re: DIS AND CRUISE RETRO FIT b6+b7
    #46
    dovski Guest
    Thx, first problem I have though is that the login function11 appears whilst interogating module, then it greys out with "coding ll 11" written in the button box???? so I cant login it would appear...
  7. Re: DIS AND CRUISE RETRO FIT b6+b7
    #47
    May 2007
    knee deep in clunge
    14 Post(s)
    just popped outside and function 11 is fine on mine vcds 805.4
    engine must be off ignition on and clear fault code or check the fault codes and post them
  8. Re: DIS AND CRUISE RETRO FIT b6+b7
    #48
    dovski Guest
    yep, 805.4 on mine too, but 15, 11 and 10 are greyed out?
  9. Re: DIS AND CRUISE RETRO FIT b6+b7
    #49
    dovski Guest
    "If you are using second hand steering column control units relearn the vin number address 16 Channel 081: Vehicle Data Learning
    To start the process for vehicle data (VIN) learning, enter/save 00111 as new value."
    WHere exactly is the code entered? sorry to be a pain A8.
  10. Re: DIS AND CRUISE RETRO FIT b6+b7
    #50
    May 2007
    knee deep in clunge
    14 Post(s)
    ok just checked open address 03 click on login 11 enter code then go back and open basic setting 01 and that's it another way is driving in a straight line for 100yards and it should reset automatically unless the angle sender is way out but check mvb for its postion
    Thursday,23,July,2009,22:20:17:24642
    VCDS Version: Release 805.4
    Data version: 20090602
    Address 03: ABS Brakes (8E0 614 517 A)
    22:20:15 Group 001: Steering Angel Sensor (G85) Alignment
    Adj. Steering Steering Angel Sensor (G85)
    Angle Sensor Alignment
    OK Alignment Status
    N/A
    here are my notes i carry when fitting away from home these are for B7 platform and login via function security access 16 instead of 11 for B6
    steering angle reset
    Basic Setting
    [Select]
    [03 - ABS Brakes]
    [Fault Codes - 02]
    [Done, Go Back]
    Start Engine (session still running).
    [Meas. Blocks - 08]
    [Done, Go Back]
    [Security Access - 16]
    Enter 40168
    [Do It!]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    dash code and adaptions
    Coding
    * 00??xxx: Options I
    o +00 = 1. K-Number (Europe/USA/Rest of World)
    o +01 = Smaller Fuel Tank Volume (All-Wheel-Drive)
    o +02 = Side Marker Lights Indicator Lamp inactive
    o +04 = 3. K-Number (Rental Cars)
    o +08 = 2. K-Number (Australia)
    o +16 = Clutch Pedal Switch Operation in FIS Display
    * 00xx?xx: Country
    o 0 = Germany (D)
    o 1 = Rest of World (RoW)
    o 2 = USA (US)
    o 3 = Canada (CAN)
    o 4 = Great Britain (GB)
    o 5 = Japan (JP)
    o 6 = Saudi Arabia
    o 7 = Australia (AUS)
    * 00xxx?x: Seatbelt Warning
    o 0 = No Seatbelt Warning
    o 1 = Seatbelt Warning Europe-NCAP
    o 2 = Seatbelt Warning USA and Canada (NAR old)
    o 3 = Seatbelt Warning USA and Canada (NAR new)
    o 4 = Seatbelt Warning Europe-NCAP (incl. passenger)
    o 5 = Seatbelt Warning USA and Canada old (incl. passenger)
    o 6 = Seatbelt Warning USA and Canada NAR new (incl. passenger)
    * 00xxxx?: Options II
    o 1 = Standard (< 11/2006)
    o 4 = Washer Fluid Warning inactive (11/2006 >)
    o 8 = Washer Fluid Warning active (11/2006 >)
    Adaptation
    Channel 029: Tank Characteristic (Fuel Level Sensor 2)
    Parallel shift of tank characteristic by +/- 32 Ohm. Only for Quattro models.
    * Standard Value: 128
    * Value Range: 96...160 (-8.0...+8.0 l)
    * Increments: 1 = 1 Ohm = 1/4 l
    Channel 030: Tank Characteristic (Fuel Level Sensor 1)
    Channel 032: Tank Characteristic (Not detactable Tank Volume)
    The tank volume which is not recordable by the fuel gauge sender(s).
    Channel 033: Tank Characteristic (Full Calibration)
    Non-parallel shift of the tank characterictic above a readout of 1/2. To start the adaptation enter '65535' as new value.
    * Value Range: 112...144 (-4.0...+4.0 l)
    Channel 034: Tank Characteristic (Dry Calibration)
    Channel 035: Speed Threshold
    This value represents the speed threshold for the dynamic oil pressure system. The threshold can be raised in increments of 250 RPM.
    Channel 060: CAN-Databus Powertrain (Installation List)
    * +00001 = Engine (Standard)
    * +00002 = Automatic Transmission (Optional)
    * +00004 = Brake (Standard)
    * +00016 = Airbag (Standard)
    * +01024 = Instrument Cluster (Standard)
    Channel 061: CAN-Databus Comfort (Installation List)
    * +00001 = Central Electronics (Standard)
    * +00002 = Comfort System (Standard)
    * +00064 = Trailer (Optional)
    * +00128 = Convertible Top (Optional)
    * +00256 = Instrument Cluster (Standard)
    * +00512 = Tire Pressure Control (Optional)
    * +01024 = Steering Column Electronics (Standard)
    * +02048 = Climate Control (Standard)
    * +32768 = Auxiliary Heating (Optional)
    Channel 062: CAN-Databus Infotainment (Installation List)
    * +00001 = Radio (Optional)
    * +00002 = Telephone (Optional)
    * +00004 = Navigation (Optional)
    * +00008 = Telematics (Optional)
    * +00016 = Intrument Cluster (Standard - only coded with 2nd Component)
    steering column code and vin reset
    * 0?xxx: Steering Wheel
    o 0 = Standard (without Multifunction)
    o 1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
    o 2 = Multifunction Steering Wheel with Radio Control
    o 3 = Multifunction Steering Wheel with Radio/Telephone Control
    o 4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
    o 5 = Multifunction Steering Wheel with Radio/Voice Control
    * 0x?xx: Options
    o +1 = Tiptronic
    * 0xx?x: Board Computer & Cruise Control
    o 0 = Board Computer & Cruise Control not installed
    o 1 = Board Computer installed
    o 2 = Cruise Control installed
    o 4 = Board Computer & Cruise Control installed
    * 0xxx?: Rear Wiper (Chassis)
    o 1 = Rear Wiper not installed (Sedan/Cabriolet)
    o 2 = Rear Wiper installed (Avant)
    Adaptation
  1. retro fit cruise
    By mike cosker in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-10-2008, 11:55 PM
  2. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
  3. Retro Fit Cruise Control
    By gazza007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2008, 09:05 AM
  4. Retro fit cruise control
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2008, 12:06 AM
  5. Retro fit A3 Cruise control
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 10:59 PM
