Thread: DIS AND CRUISE RETRO FIT b6+b7
Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 159
  1. Re: DIS AND CRUISE RETRO FIT b6+b7
    #21
    Dec 2007
    Quote Originally Posted by bez101 View Post
    one last daft question wheres channel 061
    done the codeing in 061 it was 3331 and should stay 3331 with no tyre presure thing and its still on any ideas
  2. Re: DIS AND CRUISE RETRO FIT b6+b7
    #22
    May 2007
    knee deep in clunge
    14 Post(s)
    what changes did you make to the dash adaptions/coding
  3. Re: DIS AND CRUISE RETRO FIT b6+b7
    #23
    Dec 2007
    Quote Originally Posted by a8 tech View Post
    i used your guide enabled dis 1 an 2 menu and cruise its all workin fine just that daft light aint there a pin i can pull and earth to shut it off in 17 061 its not enabled codeing was 3331 and adding the standard up comes to 3331 it was on b4 i coded anything also i kept note of old numbers and put it back today light still on
  4. Re: DIS AND CRUISE RETRO FIT b6+b7
    #24
    May 2007
    knee deep in clunge
    14 Post(s)
    Weird,disconnect the battery as for some reason there seems to be a tpms signal on the convience can.Reconnect the battery and clear fault codes and see what happens.
  5. Re: DIS AND CRUISE RETRO FIT b6+b7
    #25
    Dec 2007
    just dont the batt been off all nite the light still on checked an rechecked the codeing still the same do you know of a wire i could pull or earth
  6. Re: DIS AND CRUISE RETRO FIT b6+b7
    #26
    Dec 2007
    iv looked all through the manual and cant find this light anywhere iv found the type monitor and its wheel shapes in the dis red for flat amber for low preasure even asked a bloke at audi hes never seen it b4 and gona look for it its next to the cruise light iv tried to go into the tyre monitor in vcds but cant get in to the controler ov cos its not got it fitted it doesnt stay on steady flickers around but all ways there
  7. Re: DIS AND CRUISE RETRO FIT b6+b7
    #27
    May 2007
    knee deep in clunge
    14 Post(s)
    removed ebay sellers using info
  8. Re: DIS AND CRUISE RETRO FIT b6+b7
    #28
    Dec 2007
    tried above didnt work no faults etc i didnt change any plugs etc or remove any it came on the minute i had it all togeather igg was off and batt off reconected and turned igg and it was there
  9. Re: DIS AND CRUISE RETRO FIT b6+b7
    #29
    May 2007
    knee deep in clunge
    14 Post(s)
    removed ebay sellers using link
  10. Re: DIS AND CRUISE RETRO FIT b6+b7
    #30
    Dec 2007
    yeah i found that ant tried it 1st didnt work my mate in his 2007 can turn his on and off he found out when he had a fault on the bottle i put my old scsm on last night and coded back to what it was light went out so its got to be the scsm thanks for all your help
  1. retro fit cruise
    By mike cosker in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-10-2008, 11:55 PM
  2. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
  3. Retro Fit Cruise Control
    By gazza007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2008, 09:05 AM
  4. Retro fit cruise control
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2008, 12:06 AM
  5. Retro fit A3 Cruise control
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 10:59 PM
