Thread: DIS AND CRUISE RETRO FIT b6+b7
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 159
  1. Mfsw, dis and cruise retro fit b6 & b7 a4
    May 2007
    knee deep in clunge
    14 Post(s)
    Re posted after removing due to finding instructions used by ebay seller.
    Ok B6 model and B7 A4 saloon, avant and cab adding cruise control and dis or multi function indicator
    Only high line specified vehicles seemed to have dis fitted from factory but the software is already installed on all the dash clocks, this means we can enable the function.
    The only difference is the washer bottle level sensor which will not be fitted if you are retro fitting dis.
    For B7 models the wiring for washer circuit is fitted in part but for B6 its not
    Other members have posted the part numbers and how 2 so I wont go into it.
    However when we fit the dis/wiper switch we need to modify the circuit to turn off the warning light now enabled after encoding the steering control unit and changing the dash insert adaption channel (cover this later)
    If you wish to add cruise control then we can cover this also
    Ok firstly safety is very important so we need to follow a few steps before removing the airbag
    Turn the ignition on so the engine is off but the dash is on (please make sure you have the radio anti theft code)
    Open the bonnet and disconnect the battery earth
    Now remember when reassembling to turn the ignition back to this position before refitting the battery earth terminal
    The reason for this is simple, if the airbag deploys its most likely to do so when you turn the ignition on after removing and installing the airbag.
    Leaving the ignition key in the on position and fitting the battery terminal means you are outside of the vehicle and therefore out of harms way.
    Important
    Before handling the airbag units (e.g. unplugging the electrical connector) the mechanic must discharge static electricity by briefly touching the door striker plate, or similar.
    Attachment 9860
    As the picture shows we need to remove the two torx bolts number (6) size 25 to 30
    Then ease the airbag off the steering wheel and disconnect the wiring connector
    Now place the airbag underneath the vehicle face upwards
    Remove the central steering wheel bolt (3) 12mm spline and mark the position of the wheel with marker pen against the steering column splines for the central position of the wheel
    Now remove the steering cowling
    Attachment 9861
    Now remove the airbag slip ring
    Attachment 9862
    If you need to replace the steering control unit then remove all the screws for the switch packs and simply swap it all over
    Attachment 9863
    Now dis/wiper switch needs swapping and also add the cruise switch and refit the switch pack steering control unit and slip ring.
    Now remove the dash panel insert to modify the washer circuit for dis
    Attachment 9864
    torx screws again and should be size 20/25
    Pull the dash towards you and disconnect the multi plugs, locate the blue plug and remove the wire from pin 1 if present and replace it with oem wire part number 000 979 164E and run the wire to the earth bolted connection behind the dash on the bulkhead (10 mm nut) you will see it its obvious.
    Ok refit everything remembering the battery procedure for the airbag.
    important
    The ignition key inserted and turned on (nobody inside the vehicle)
    When connecting battery, attach battery clamp of earth cable to negative battery terminal “–” by hand and tighten nut.
    Now if there are no loud bangs then its safe to enter the vehicle
    Continue
    Connect vcds
    address 16 use long code helper add cruise and on board computer change byte 4 to 2 or 4 with cruise and on board
    example
    address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0601
    Coding: 03041
    4th byte changed for cruise and dis (on board computer)
    Notice the steering control unit part number Q revision or R revision for B7 or you can fit these revisions for B6 also
    address 01 use login 11463 and enable cruise but if its tfsi or 3.0/2.7 tdi you need enable the long code byte number 6 to enable cruise
    address 17 go to adaption channel 19 change byte add dis function
    vcds screen shot for b6 setting
    dis setting by a8 tech, on Flickr
    example B7 address 17:8E0 920 951 E channel 19 adapted to 31300 for level 1&2 plus menu
    reset all fault codes drive vehicle 20 meters or so to reset esp/steering angle position. or re set http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    Check clutch switch mvb 6 address 01 or use advance measured values as the group changes for differing ecu protocols, this needs to be checked as if the switch sticks then the cruise will not function.
    vcds measured value log of faulty clutch switch stuck on 1 (the three 1's are clutch switch, brake switch, brake switch)
    clutch pedal switch stuck on by a8 tech, on Flickr
    you need to see the byte change from 0 to 1 or visa versa as you press and release the clutch.
    I will add a log to run through the coding etc
    Part numbers
    If you have a multifunction steering wheel then you already have the correct steering control unit and therefore only need the
    LOWER COWLING 8E0 953 512 (COLOUR code)
    CRUISE SWITCH 4E0 953 521 (COLOUR CODE)
    WIPER SWITCH/DIS 4E0 953 503 (COLOUR CODE) AVANT AND SAL0ON DIFFER
    REPAIR WIRE 000 979 009 E
    RINGLET TERMINAL
    You only need to replace the steering control unit if adding cruise control without multifunction steering wheel
    Dis will work with all steering control unit revisions
    If you wish to upgrade B6 to dis and cruise then I advise you fit steering control unit Part No: 8E0 953 549 Q or R
    Again if you have a B7 WITHOUT MULTI FUNCTION STEERING WHEEL YOU NEED THE SAME CONTROL UNIT
    HOW TO RETRO FIT MFSW FOR B7 MODELS
    The steering wheel isn't cheap so ebay is a good place to look
    If you have a B7 and wish to add multifunction steering wheel you will need to replace the steering control unit with
    8E0 953 549 Q or R
    Also you need
    Airbag slip ring 4E0953541A or B
    If you look at the slip ring and you look at the connection from the steering wheel airbag plug then the slip ring needs to have all 12 pins populated
    The image below (bangor lads) shows only 6 pins populated so it needs replacing for mfsw
    http://184.72.239.143/mu/5e0e7a61-3e4f-bc38.jpg
    If only the top row is populated then you need to replace the slip ring for the multifunction controls to operate as they use the lower row of pins
    And
    Airbag steering wheel loom
    4F0 971 589 A
    Also and revisit address 16 and encode to add the function plus address 56 radio and address 77 if you have phone.
    Also if you have phone preparation recode the telephone control unit address 77 so you now can use the push to talk button on the steering wheel
    vag diagnostics, retrofits and general repairs
    8 2 0
  2. Re: DIS AND CRUISE RETRO FIT b6+b7
    Jun 2008
    Marmitehampton
    Great post!
    If you want to retrofit the washer bottle you will need the following:
    Washer bottle sensor: 7M0 919 376
    Contact Housing (plug): 1J0 973 202
    Connector Wires: 000 979 009A
    Connector Wires: 000 979 133A
    Parts cost around £17
    The other end of the instrument cluster Pin1 wire is in the passenger side footwell:
    • Remove the glovebox, the trim along the sill and the triangular shaped piece of trim in front of the door. There a number of plugs for the wiring loom behind here.
    • Remove the nearside front wheel and wheel arch lining
    • Remove the plastic strut at the front of the wheel arch
    • Remove the bolts securing the washer bottle and gently pull it down slightly. You don't have to fully remove it and be careful not to pull the rubber tube out
    • Turn it roundand remove the black bung.
    • Fit the sensor. Insert the repair wires in to the plug then fill the back of the plug with some silicone, then fit the plug to the sensor.
    • Refit the washer bottle to the car and earth one side of the sensor
    • With the other side of the sensor, route a cable up and along the top of the wing (following the wiring loom) and then on the right in the bulkhead there is a rubber grommet, snip the end off and feed the wire through.
    • On the inside of the car insert a repair wire in to Pin 9 of the black plug (red and brown wire)... * Please check this is the correct pin and wire - I'm pretty certain it is, but check to be sure... I used a multimeter to be sure. It is easier if you remove the bracket the bracket the plugs are fixed to and then remove the black plug.
    • Connect the repair wire to the other end of the sensor wire.
    • Refit everything.
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
    2 0 0
  3. Re: DIS AND CRUISE RETRO FIT b6+b7
    Leicester
    If anyone finds the coding tricky to work out, I have written an Idiots Guide - see the link in my Sig.
    Ade
    3 1 0
  4. Re: DIS AND CRUISE RETRO FIT b6+b7
    May 2007
    knee deep in clunge
    14 Post(s)
    Q5,B8 A4 and A5 cruise retro fit requires the switch pack and lower cowling, only none muti function steering wheels need the additional steering angle/airbag slip ring
  5. Re: DIS AND CRUISE RETRO FIT b6+b7
    Dec 2007
    a8 quick question on the B7 dis fitting u say its a blue plug wire 1
    well on this b7 its a black plug pin 1 is a thick brown wire the 2 a power wire other 16 thin wires what wire needs earthing to get washers off ?
    any idea
  6. Re: DIS AND CRUISE RETRO FIT b6+b7
    May 2007
    knee deep in clunge
    14 Post(s)
    Pin 1 needs to be earthed,b7 has the brown and black tracer wire fitted for the washer circuit but this stops at the nsf A pillar,just earth the wire,B6 has no wire in pin 1
  7. Re: DIS AND CRUISE RETRO FIT b6+b7
    Dec 2007
    Quote Originally Posted by a8 tech View Post
    so its the big wire 1 an 2 are big wires the rest are thin wires if u pull the plug apart 1 an 2 stay in one part ov the plug the others stay in the other part ?
  8. Re: DIS AND CRUISE RETRO FIT b6+b7
    May 2007
    knee deep in clunge
    14 Post(s)
    Remove the outer blue cover and find pin 1,de pin and fit a new wire with contact (i posted the wire part number) run this to the earth point behind the dash inserts fitting position and fit eyelet connection to your wire and locate at the 10mm nut earth point.Or strip the wiring loom tape back from the blue connection and extend pin 1 wire to reach the earth point
  9. Re: DIS AND CRUISE RETRO FIT b6+b7
    Dec 2007
    it aint a blue cover the plug is black 2 thick wires 1 2 and then when u remove black cover that hold 14 small pins the 1 an 2 stay in the cover i got the wire in case i needed it but the number 1 wire in plug is thicker i shoulh have took a pic ov the plug
  10. Re: DIS AND CRUISE RETRO FIT b6+b7
    Aug 2008
    Hi all,
    I have succesfully fitted DIS to my 52plate (2003 model year) A4 avant 1.9 tdi Quattro.
    The washer warning light is on all the time.
    I purchased repair wire prt number 000 979 020 (1 set of S) But it has male connection pin on the end where as its a female connector thats needed for inside pin1 of blue connector. Can anyone help??
  1. retro fit cruise
    By mike cosker in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-10-2008, 11:55 PM
  2. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
  3. Retro Fit Cruise Control
    By gazza007 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2008, 09:05 AM
  4. Retro fit cruise control
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2008, 12:06 AM
  5. Retro fit A3 Cruise control
    By alibla in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 10:59 PM
