Thread: Temp gauge reading low
Results 1 to 10 of 14
  1. Re: Temp gauge reading low
    South Moreton, Oxfordshire
    Quote Originally Posted by RickT View Post
    More than likley the thermosat... HOWEVER if the thermo sat is staying closed the engine temp should go upto 90'c after 10 mins or so of driving as the collant will not be running around the engine..
    The themo is a bit of a bugger to do.. but easy when you know how when you have the alternator off..
    The coolant temp sensor also has a syptom of reading the engine temp lower than it is..
    If you cant do it your self, let me know and i can sort it out for you via a mate.
    Rick
    Cheers Rick, I would suspect the Thermostat as the car is not getting warm inside, after 10 mins it should be nice and cosy inside, plus it warms up when stood still and cools down when moving.
    I should manage the thermostat myself I'm just confused that Haynes should give it the same difficulty level as changing the clutch.
  2. Re: Temp gauge reading low
    it would seem that the thermostat is stuck in the open position, allowing the coolant to circulate through the rad,instead of keeping it confinded to the block/head when cold,as
    suspected above.
    if you haven't changed one of these thermostats before you will be suprised by the look of it
    as it isn't anything like a"normal" one.
    i would suggest you try a search, as it needs to be "located" correctly,and be very careful
    when tightening the housing (plastic),i believe,and is easily cracked apparently.
    i haven't done one myself,i'm only going on what the forum members have shared in the past, which shows the value of the "search" facility.
    regards,
    stewy.
    4th cog,--two to go
  3. Re: Temp gauge reading low
    Dec 2007
    it can be done with alt in place but fiddly ill take alt off next time will get to it much easyer
  4. Re: Temp gauge reading low
    Dec 2006
    Quote Originally Posted by Andy J View Post
    I have a themosat in the boot of my car which i took off a few weeks ago thinking it was faulty.... (it turned out to be the head gasket)
    The themo sat had only been on the car for 6 months!! LOL!!
    Never mind!
    Ensure you had a breaker bar to release the tension of the alt belt..
    Rick
  5. Re: Temp gauge reading low
    Ricky, now you've worried me, I've just had a little play under the bonnet just to familiarize myself with the task, doesn't look too hard. Now the bad bit, I removed the oil filler cap and noticed a very small amount of emulsion on the cap, the dip stick shows clean oil and the water has no sign of oil in it So I'm hoping it's the result of the cold weather as I haven't used the car for a couple of days.
  6. Re: Temp gauge reading low
    Dec 2006
    Give the oil cap a clean and then check it again after around 10miles... then 50 miles..
    When the temp gauge is at 90'c does it blow totally cold??
    Rick
  7. Re: Temp gauge reading low
    Rick
    The temp gauge barely moves above 50 but the heater does blow warmish but not enough to make the car comfortable especially in last weeks cold spell.
  8. Re: Temp gauge reading low
    So far no more emulsion on the oil filler cap.
    I've done the old trick of blanking half the radiator with a peice of card, got the temp half way between 50 and 90 with the vehicle stationary, this is better than I've managed before so I'm guesing the thermostat is stuck open.
  1. Temp gauge not reading right
    By Andrew1408 in forum Chat - Anything with wheels
    Last Post: 26-09-2008, 07:41 PM
  2. fuel gauge reading
    By surgey in forum Audi A3 - Archive Topics
    Last Post: 22-04-2008, 03:45 PM
  3. no gauge temperature reading
    By nicho in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-03-2008, 11:57 PM
  4. Temp Gauge reading
    By Spaceman in forum Audi A3 - Archive Topics
    Last Post: 07-03-2007, 04:40 PM
  5. A4 Temperature Gauge not reading
    By GT001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2007, 04:11 PM
