Thread: What to look out for on PD150
Results 1 to 10 of 12
  1. What to look out for on PD150
    Great Dunmow (near Stansted Airport), Essex
    Hello,
    I am seriously considering purhasing an '02 plate Golf GT PD150.
    77k on the clock.
    Some minor stone chips at the front, but have been touched up.
    £5995 (price is negotiable)
    I there anything in particular I should be looking out for, incase I buy a turkey? Only thing to note is there is no engine cover, as the previous owner has put an aluminium Samco hose running from the air box...
    http://www.whitleybridgecarsales.co....d=AETV91274533
    What do you guys think?
    1990 Black MKII Golf 1.8 GL. Otherwise known as 'Gumpert' Rampant "Rabbit"
    2011 Rosso Brunello Skoda Superb Estate Elegance 1.6 CR Greenline. Otherwise known as 'Sue'
    1988 Tornado Red MKII Golf 1.8 16valve GTI. Otherwise known as 'Hollie' - Project
  2. Re: What to look out for on PD150
    Apr 2009
    Quote Originally Posted by macmillions View Post
    Hello,
    77k on the clock.
    Obviously when buying any car you wanna do the following things?
    - HPI Check the car (https://www.mytextcheck.com/)
    - Look through the service history? Is it regular?
    - Look through the previous paperwork and see what has been done and consider what may need to be done, in the future.
    Regular Services from a VW Dealership, would suggest that the correct oil has been used in these engines, these engines can be your best friend or your worst nightmare depending on how they have been treated.
  3. Re: What to look out for on PD150
    Apr 2009
    Manchester
    Seems a tad pricey to me to be honest. I picked my '03 plate PD150 up a few months back for £4800... 98k on the clock, air con, cd changer, excellent inside and out etc
  4. Re: What to look out for on PD150
    Dec 2007
    New Mills, Derbyshire
    It MUST have been run on the correct PD spec oil, and NOT been on the longlife service shedule (Oil change every 20000 or so miles!)
    https://www.vwaudiforum.co.uk/forum/s...light=oil+spec
    Just one of the many posts about PD oil, so you get the idea!
    Buy one thats been on the wrong oil and it will cost you £xxxx!
    150 GTI DIESEL - propper juice!!
  5. Re: What to look out for on PD150
    Mar 2009
    Gillingham Kent
    Check Crashers last post in this thread
    https://www.vwaudiforum.co.uk/forum/s...ight=money+pit
  6. Re: What to look out for on PD150
    Hmmm... So as Crasher says the 150 is a money pit. I assume, after having done a bnit of trauling through the forum that if the PD oil isn't used, Turbos clog up and fail, and as been mentioned camshafts have a nasty habit of failing.
    But the thing that concerns me most is the Dual Mass Flywheel. When the clutch dies, if its not replaced soon enough, the flywheel is knackered. costing mega bucks.
    Do all these problems seem to be as common on the PD130? (I'm sure the power would be plenty, as it's for 'er indoors, as the old bad boy Mk2 is dying a death now, so moving from 90bhp - when new anyway, to 130bhp with bucket loads of torque would be a big leap anyway).
    Yea I think the price is that steep as it will be given a service and MOT when sold, plus a years tax.
    The thing is, she wants it in black, and no other colour. And the black ones all seem to be slghtly more expensive...
  7. Re: What to look out for on PD150
    Mar 2009
    Gillingham Kent
    Have had my 150 for just over a year the only problems I have had are
    Brake light switch replaced
    Lower intercooler pipe coming off, new pipe fitted twice
    Alternator pulley replaced
    Vacuum pipe coming loose.
    Also had oil & filter change between services
    After reading various posts, I think I'm getting off lightly at the moment
  8. Re: What to look out for on PD150
    Jun 2009
    Manchester/Cambridge
    Make sure it's had a cambelt service at the right time, if you can't verify, get it done and don't take anyones word for it.
    Also check ARB, inner/outer links, if they've not been changed they will need to be at some stage.
    Similar probs with PD 130 for common shared parts, so all of above ect, though PD 150 has additional ones and even more rarer/expensive parts....
    ________________________________________//
    Golf Mk4 GT TDI PD 130
    Tiguan Sport 2.0 TDI 170 4Motion
  9. Re: What to look out for on PD150
    Jun 2009
    Also, don't go by milage on cambelt changes, go by year, it should be changed every 4 years as rubber starts to degrade after that time.
  10. Re: What to look out for on PD150
    Jun 2009
    Bit like keeping a high maintenance women, expensive, but scream on demand and like being pumped hard....
  1. Please Help TDI PD150 problems (again!)
    By Dannyg81 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-05-2009, 02:03 PM
  2. Worthy Successor to Mk4 Golf Tdi PD150
    By iworld in forum Golf MK4 - 1999 - 2004
    Last Post: 21-04-2009, 05:37 PM
  3. BMC / CDA INTAKE SYSTEMS for PD150 MkIV
    By KashBash in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 10:57 AM
  4. PD150 on PD130 Help
    By Stu_c in forum Golf MK4 - 1999 - 2004
    Last Post: 01-12-2007, 01:28 PM
  5. Replies: 2
    Last Post: 14-10-2007, 11:32 PM
