Thread: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
  1. Post A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Apr 2007
    Dear all, sometimes when I start my Audi after stopping for a few minutes it does'nt start first time. As soon as i turn the key, the starter turns as per usual but there is a very LOUD Clunking noise for about 2 seconds whilst the car is trying to start. Sometimes it just makes a bad noise. As soon as the car has started the clunking sound dissapears. The problem is only on warm start. From cold the car starts excellent. P.s I have recently had a Pipercross sports air filter fitted and oil change. I also changed the starter but no difference. Also, every time i take it to the garage it never goes wrong.
    Any advice would be most appreciated.
    Kind Regards.
  2. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Apr 2009
    essex uk
    Think it would be very difficult to diagnose/pinpoint the problem, however, quite alot of these situations are resolved by covering the boring basics/obvious places.
    Have you had a chance to repeat the lead up to the noise, but get someone else to start it up, so you can bung your head under the bonnet and at least possibly locate where exactly its coming from. Hope it helps.
  3. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Jan 2009
    Birmingham
    36 Post(s)
    Have you had a scan on it to see if any codes and one more thing the airfilter you pit on if it's oil based then that will kill your maf So do a scan first
  4. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Mar 2010
    london
    Quote Originally Posted by nadeem1919 View Post
    Kind Regards.
    i have exactly the same problem.i narrowed it down to the flywheel but im still on denial couse its a lot of money to do it. unfortunately thats very common problem for a4 tdi and if you dont do it it will ruin your gearbox. let me know how it went for u.
  5. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Oct 2010
    Lancs
    Hi, I to have the same fault.. Cold start is fine but on a hot start the car sounds like a bag of spanners... You mentioned the flywheel could be faulty but my car is an automatic.. Has anyone resolved this issue..?
  6. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Apr 2009
    Somewhere....Over The StrongBow
    The clunking may be secondary to your hot-starting problem, try replacing
    the coolant temp sensor.
    Regards
    Jim
    Still Crazy After All These Gears
  7. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Oct 2010
    Lancs
    Thanks Jim, I have changed the coolant sensor and it's still the same, scanned with VAG-com etc, no faults present.. Not sure what angle to take now..
  8. Re: A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    Apr 2009
    Quote Originally Posted by greent2 View Post
    Thanks Jim, Not sure what angle to take now..
    Next step is to get an 'engine measuring block scan' done.
    Regards
    Jim
  1. Air con & starting problems A4 Tdi 130
    By Dansk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2007, 10:10 PM
  2. Starting Problems!!!
    By maniVW in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-04-2007, 01:40 PM
  3. a4 2.4 v6 starting problems
    By 00carberry00 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-03-2007, 08:37 PM
  4. Starting Problems
    By vaslam1986 in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 04:20 PM
  5. A4 1.8 Starting Problems
    By cmartin in forum Audi A4 - Archive Topics
    Last Post: 07-01-2007, 09:24 PM
