Thread: A4 1.8 Starting Problems
  1. A4 1.8 Starting Problems
    Dec 2006
    Hi I’m new to the forum so go easy!
    I am having starting problems with an A4 1.8 non turbo. It is an intermittent fault where by the car will start rev to around 2,000 and then die.
    I am guessing that it could be the idle control valve but someone mentioned to me that it could be the immobilizer? Had anyone got any experience with this problem and/or know how much an idle control valve might be.
    london/ UK
    If its the immo you will see the light flashing in the dash and the car will stop 1 sec after it starts. I suspect the idlle stabilisation valve (check if it has one !) or a defective throttle body. Get the car scanned for fault codes as that will narrow the search a bit. Good luck.
    Dec 2006
    Thanks for the responce, there is no light on the dash so I guess that rules out the immonilizer, we have just managed to get the diagnostics done and has come up with idle sys responce valve which I presume is the same as the stabilisation valve.
    Is there an online parts catalog for audi's simular to www.realoem.com for BMW's?
    Dec 2006
    Quote Originally Posted by adamss24 View Post
    We have been able to do a little more work with this car, the alarm light is activating, and the diagnostics has come up with
    17978 Control Module Locked
    In the code book, it is listing an immobiliser error posibly a broken key, does anyone have any experience of this? Is it posble to permanently disable the alarm and Immobiliser?
  1. A4-Tdi STARTING PROBLEMS!! PLEASE HELP
    By nadeem1919 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-08-2011, 06:56 AM
  2. Air con & starting problems A4 Tdi 130
    By Dansk in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2007, 10:10 PM
  3. Starting Problems!!!
    By maniVW in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-04-2007, 01:40 PM
  4. a4 2.4 v6 starting problems
    By 00carberry00 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-03-2007, 08:37 PM
  5. Starting Problems
    By vaslam1986 in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 04:20 PM
