Thread: First Time '02 A6 1.9 TDi Owner Questions
Results 1 to 10 of 16
  1. Question First Time '02 A6 1.9 TDi Owner Questions
    Apr 2011
    Dover
    I recently bought an '02 A6 1.9 TDi Sport and have been reading up and trying to learn a bit about the car that will stand me in good stead with regards to the vehicles up-keep. I thought i would ask a few questions as i figured this forum would contain a wealth of knowledge. Firstly, i am considering getting a full service done as i thought it wouldn't hurt, even though the dash display say's "Next Service Due in 5000 Miles". Would this be a waste of money? If i should get a full service, what would i expect to pay and would anybody recommend a good place to get the work done?
    My second question. I was made aware by the dealer that there was a problem with the power steering belt tensioner whereby when on full lock, the steering makes an odd sound. Again, could anybody give me an idea of where best to get it done and a rough cost i would expect to pay.
    My third - where would be the best place to get some spare parts that i could replace myself. I noticed that there is an aluminium strip along the bottom edge of the boot and it looks a bit scratched and tatty. I thought buy a new(er) looking replacement to tidy it up a bit.
    Finally i thought i would try to find out what common problems occur with this car and maybe an easy way or early warning sign to look out for, when these problems are about to rear their head.
    I live in Kent if anybody does suggest places to consider. I've also looked at some online company's who claim to do a decent job as far as the service/repair is concerned. Any input would be appreciated.
    Regards
    RizlaUK
  2. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2009
    Somewhere....Over The StrongBow
    Quote Originally Posted by RizlaUK View Post
    Depends on the last time the engine-oil and filter was done? Try to do
    it every 10k miles.
    You can DIY the oil and filter changes, keep recipes of the parts, and
    enter the job into the service book. You can change the dash display
    yourself.
    The boot plate is an Audi part.
    Regards
    Jim
  3. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2011
    Dover
    Quote Originally Posted by yaman View Post
    it every 10k miles.
    yourself.
    In the service book it lists the last service done 03/07/09 @ 65k miles. So it's worth getting it done i suppose. I have been quoted
    £150 + VAT by a local garage for the full service. The power steering belt repair was quoted at £190 + VAT, as they have to take the radiator and bumper off to access it, apparently.
    I've also had an online quote for the full service of £278.4 inc vat from: http://www.service4service.co.uk/
    Nearly £100 difference, is it a case of cheaper isn't always better, or is somebody just taking the p*ss?
    Regards
    RizlaUK
  4. Re: First Time '02 A6 1.9 TDi Owner Questions
    Jun 2007
    How many miles has the car done. As the front has to go into the service position for the power steering issue, then as you are approaching the cam belt change both in years and miles you should consider having it all done at the same time. Search for an Vag independant specialist in your area. Regards Peter
  5. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2009
    In the service book it lists the last service done 03/07/09 @ 65k miles. I've also had an online quote for the full service of £278.4 inc vat from: http://www.service4service.co.uk/
    What mileage is it on now?
    There's a massive difference in the prices charged by various
    work-shops for the same jobs, they all have different
    over-heads..... and under-hands .
    Unfortunately price is not an indicator of professionalism. But
    personal recommendation is, and some of the members here
    will have advice of services in your area.
    Regards
    Jim
  6. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2011
    Dover
    Quote Originally Posted by Peter D View Post
    The car has done 75K and the timing belt was changed at 60k in 2006.
  7. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2009
    That's truly amazing, just 15k in 5years! Must have been owned by
    a retiree, who had enough of galloping around the country
    And yes, time-wise the timing-belt is due for changing.
    Regards
    Jim
  8. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2011
    Dover
    Hmm so it's looking better to get it all done in one hit, cambelt/power steering/service. Is it best to put it in for the service and let them advise me or just state what I want done? That also sounds like it's going to cost a bit, any idea on a worse/best price scenario? I've got a 3 month warranty from the dealer I bought it from so that will give me some time to get the dough. I'm totally green when it comes to cars so forgive me if I'm asking obvious questions and thanks for the input so far.
  9. Re: First Time '02 A6 1.9 TDi Owner Questions
    Jun 2007
    Are you sure the car has only doen 15k miles in 5 years.
    "The car has done 75K and the timing belt was changed at 60k in 2006."
    Regards Peter
  10. Re: First Time '02 A6 1.9 TDi Owner Questions
    Apr 2011
    Dover
    Regards Peter
    It's what it says in the service book, it's a full Audi service history. Is there any other way I could double check aside from the service book. Also I've been quoted £185 Inc Vat from the local Kwik-Fit. What do you think?
    As a side note I did do one of them checks to make sure it's hpi clear/ not write off etc etc. It all came back sweet and the milages where listed on there too at different intervals.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Audi A6 VagCom Scan Results.
    By cwilding in forum VCDS - Help Requests
    Last Post: 19-11-2010, 10:19 PM
  3. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  4. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
  5. The new Audi A6 Avant
