Thread: Vibrating Gear Knob
Results 1 to 10 of 10
  1. Vibrating Gear Knob
    jshodgson Guest
    Hi
    I noticed that my gear knob started to vibrate when idling if I had my air con on. Now it bibrates without the air con on and I think I can hear a rattle coming from the engine.
    Any ideas please?
    A4 TDI (red I) 1998.
  2. Re: Vibrating Gear Knob
    Aug 2008
    Hi,i had this very same problem recently on my own tdi (red i ) and sent it into be repaired thinking it might be a rear mount needing replacement ( which is alledgedly common in these)
    turned out my 3rd injector was knackered causing the wobbly idle!! Out they all came tp be cleaned etc, replaced No.3, re-fitted, engine tested, running perfect! ..... gear knob still vibrating
    take two.
    flywheel
    not 100% on the tech stuff but was explained to me that they've a 2 piece flywheel and they were outta balance
    decided to leave it as i was told was didn't really pose any major threat.
    sorry if none of that helps but be no harm to check those 3 listed!
  3. Re: Vibrating Gear Knob
    london/ UK
    Dual mass flywheell...It will cost more than what the car's worth to put right as it will need a new DMF and a clutch kit as well !
  4. Re: Vibrating Gear Knob
    Jan 2008
    Hello i agree with adamss24 if you are getting it replaced there may be a solid conversion i know there is one for the pd engine.good luck
  5. Re: Vibrating Gear Knob
    jshodgson Guest
    MY audi has 220,000 miles and is probably worth £1000 in bits so I won't be doing any major work on it !
    Someone said to me that my water pump ma be on teh way out. How would I tell?
  6. Re: Vibrating Gear Knob
    Jan 2008
    If your water pump is on its way out it may make a harsh wining sound or it could be leaking or the blades may have fallen of the pump but when any of the above happens you will know there is something wrong.
  7. Re: Vibrating Gear Knob
    Jul 2008
    mine vibrates so much I cant keep my hand on it during motorway driving
  8. Re: Vibrating Gear Knob
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by Everton View Post
    you shouldn't be keeping your hand on it during motorway driving it says in my manual that this will wear the selector forks.
    Nothing to see here, move along..
  9. Re: Vibrating Gear Knob
    Jul 2008
    I'll bare that in mind, I think the person who owned it before me has worn more than the selector forks out on mine I'm sorry to say. Is that where the rattle comes from, the selector
  10. Re: Vibrating Gear Knob
    Mar 2008
    Just Cumbria now.
    I'll read the manual tonight and let you know
  1. Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    By frost015 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-03-2009, 09:08 PM
  2. Important Vibrating noise when turning in 1st gear/ reversing
    By NDK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2008, 06:31 PM
  3. Audi A3 Gear Knob
    By Goggz in forum Audi A3 - Archive Topics
    Last Post: 22-05-2008, 08:03 PM
  4. Replacement Gear Knob
    By dngood in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 23-07-2007, 01:23 PM
  5. Gear Knob insert?
    By valley rower in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-07-2007, 10:26 AM
