Thread: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
Results 1 to 9 of 9
  1. Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    OK, I have the new Gaiter, have taken the Knob off (thanks to help from other postings at this forum) and have it in unverted umbrella position… BUT … can't for the life of me see how to get the Black Plastic collar (which holds the gaiter to the gear knob) released, and thus .. although I can probably pull the old gaiter off, will be stuck trying to poke the new gaiter into a small gap ...
    Does this black collar come off ??
    Should I CUT it off ??
    Does it TWIST off ??
    Any help gratefully received, as I would prefer to do the job properly and none opf the postings appear to address this ...
    Thanks !
    Ian
  2. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    Hi If you want a pic send your e-mail address
  3. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    All sorted (thanks to Kenney ) .. Basically you prise the black plastic collar off the gear knob (using a flat worn screwdriver applied carefully one side, then the other, until it comes off) .. this releases the gaiter … Rest is obvious (if a bit tricky) ..
  4. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    I'm a newbie to the forum, and noticed the same question..
    Found another post that explains what I need to do... and the member refers to a jubilee clip... cool..
    I need to change my gaiter as well (MK4 Golf). I've lifted the old gaiter that has this metal ring that looks like its crimped into place. Did you have this on yours.
    Should I just cut this crimped ring?. I'd welcome any suggestions on what to do and how to replace this crimped ring assuming I have to cut it. I was thinking maybe a small jubilee clip ??
    Last edited by m4nix; 22-07-2008 at 04:30 PM. Reason: Found another post for the same thing...
  5. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    Am away on business at the moment ... but have a diagram somewhere...
    I really cant remember what I did with the crimped metal thing, but DONT cut it ! I do remember that it was re-usable.. (I think I prised it open, then re-used it ... Key is in the black thing refered to above !
    Will post diagram when I get home ...
    Ian
  6. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    Thanks Ian appreciate your help. I've ordered a new gaitor on e-bay should be getting this soon..
    Cheers..M
  7. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    Mar 2009
    Just done this gaiter replacement myself on a 2002 Golf Mk4 5-speed manual. Old gaiter came off the base OK, lift it right over the gear knob to expose the crush clip. Force a screwdriver into the crush clip to open it out enough to slide over the (light grey) plastic retaining clips, then open these out gently with a wide-bladed screwdriver and the gear knob should lift off. You'll then wonder how to get the old gaiter off as it looks like everything is glued together - don't worry, it isn't. Just work a flat-bladed screwdriver in one side, then the other and the black retaining outer sleeve will come free and the gaiter will be released. Put the new gaiter on and push the sleeve home again (I tapped it home with a hammer and a piece of plastic pipe), replace the gear knob on the stick and crush the clip back on. If the crush clip is too damaged to reuse, cut it off and retain the gearknob with a jubilee clip or as wide a tie-wrap as you can get on. To get the gaiter base on snugly it is easier to remove the plastic surround from the central console of the car (it is easy to unclip from the back and slide out backwards), fit the gaiter over it and push the surround forwards and down to get it back into the console. Hope this helps! Thanks for the earlier answers which enabled me to piece together all of this and get a decent job done.
  8. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    S Wales
    I cut the clip off and replaced it with a zip-tie. Had no problems.
  9. Re: Mk4 Gear Knob Gaiter - Gaiter to Gear knob connection
    Quote Originally Posted by MarkRuthin View Post
    Thanks, I managed to do the same. I used a jubilee clip. I tried a cable tie first but could not get it to hold tight enough..
  1. gear knob removal
    By carl12045 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2008, 06:57 PM
  2. gear gaiter
    By red.2 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-11-2007, 05:33 PM
  3. Gear Gaiter
    By Brekka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-07-2007, 11:05 AM
  4. Passat B5.5 Remove / Refit Gear Knob/Gaiter
    By RobBentley in forum Passat - Archive Topics
    Last Post: 12-07-2007, 02:40 PM
