Thread: Vent Temperature Sensor Location
  1. Vent Temperature Sensor Location
    Mar 2013
    Northwest
    7 Post(s)
    We are having the problem of one side of the cars ventilation system blowing hot whilst the other side is blowing cold.
    After searching on this issue it appears that a failed temperature sensor is likely to be the cause, but I'm unsure where they are located. Some suggest that they are located within the side vents but others say they are located behind the a/c unit in the centre console.
    Can anyone confirm their location and how easy they are to replace?
    Audi A6 Allroad 245 in Dakota Grey (2013)
    Audi SQ5 (C+S) in Ultra Blue (2022)
    Yamaha DT400E in Competition Yellow (1977)
  2. Re: Vent Temperature Sensor Location
    2010 Post(s)
    What is the VIN?
  3. Re: Vent Temperature Sensor Location
    Mar 2013
    Northwest
    7 Post(s)
    What is the VIN?
    I've pm'd you the number.
  4. Re: Vent Temperature Sensor Location
    2010 Post(s)
    They are in the main duct after the short duct which connects to the event, part number 3D0 907 543 A and £37.34 retail inc. We have done a passengers and that was glovebox out, drivers looks evil. It would be sensible to study the measuring blocks first to see what they are feeding back.
  5. Re: Vent Temperature Sensor Location
    Mar 2013
    Northwest
    7 Post(s)
    Would that be part ID 37 in the following?
  6. Re: Vent Temperature Sensor Location
    2010 Post(s)
    yes
  7. Re: Vent Temperature Sensor Location
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Remove the lower trim under steering wheel and you should be able to access it from there. Also check measuring blocks in vcds for temp readings
  8. Re: Vent Temperature Sensor Location
    Mar 2013
    Northwest
    7 Post(s)
    Quote Originally Posted by morski View Post
    What should I expect to see? I have OBD11 instead of VCDS, will I still be able to check the measuring blocks? If so where will I find them?
  9. Re: Vent Temperature Sensor Location
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    Quote Originally Posted by Allroad_2013 View Post
    No idea about OBD11, but in VCDS, the reported temperature value should be consistent with the air coming from the vents- So with the engine cold, the reported temperature should be ambient, and the same as the other side, as the engine warms the reported temperature should rise. If this is the case, the sensor is fine, and a damper flap motor has seized.
    If the sensor is faulty, it will be reporting a temperature lower than the zone's set point on the climatronic unit, which is opening up the heating flap to try to achieve the set point temperature.
    A totally implausible value, ie -200 should trigger a fault code.
  1. Please Help Temperature Sensor location
    By mercer2773 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-11-2012, 04:25 PM
  2. Location of fuel temperature sensor
    By maddogphysics in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-01-2011, 08:58 PM
  3. Coolant Temperature Sensor Location
    By gorillamonsoon in forum Audi A3 - Archive Topics
    Last Post: 13-03-2009, 02:18 PM
  4. Temperature sensor location?
    By wid77 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2008, 09:11 PM
  5. Coolant Temperature Sensor Location
    By lunatixantix in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-06-2008, 12:00 PM
