Thread: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    Hull, uk
    Hi guys, I am new to this forum.
    I have got a problem of my golf GT TDI 150 Engine.
    The funny knocking sound exactly the same as the engine shown in the video I found.
    http://smg.photobucket.com/albums/1003/Matt.H/VW%20Golf%20GTTDI%20150/?action=view&current=P1000569.flv
    It will only happen when the engine is cold, it cures itself when the engine warms up or at 70C-80C. It seems to play in a special rhythm (like having a party inside) when the
    tapping noise happen.
    I have been told by different people with different possible causes. But before I do any further action. i would like to ask for you guys advice first. cause it always helps.
    Thanks very much!!!!
  2. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    I am interested to find out too, mine does exactly the same, it does it in cold weather but once its warmed up stops!!! Mine is also a Golf mk4 GT TDI ARL engine code (PD150)
  3. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    131 Post(s)
    1979 Post(s)
    Sounds like DMF failure to me.
  4. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    Cheshire - UK
    Had a similar problem with seat - was related to Dual Mass Flywheel (DMF) - replaced under warranty and had no further problems.
  5. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    Hull, uk
    Hi, Thanks for your reply.
    It might be a silly question to you, but why would the knocking happen only when the car is cold. I would assume the knock will presist if that is cause by the flywheel, coz the flywheel will stay the same no matter what temperature it is in.
    I might be wrong, thats just what I guess.......
    Thanks!
    Keawe
  6. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    May 2008
    need some advice on my TDi Anniversary re knocking noise...i'd like to speak to crasher but need 5 posts or more!!
  7. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    May 2008
    I've got exactly the same problem. need to know if its DMF failure or cam & lifters????
  8. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    May 2008
    I've just watched the video link & i'm pretty sure thats what's wrong with my car...do you know if engaging the clutch is a sure way to tell if it's DMF is failing???
  9. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    Jul 2007
    If you depress the clutch and the noise goes, or reduces significantly, its the DMF.
  10. Re: Golf GT TDI 150 Engine Knocking / Tapping / Rocking Noise
    Hyde
    Quote Originally Posted by keawe View Post
    Keawe
    If the flywheel were to expand when it became warm or hot, it may well trap any loose components..
    It also sounds like a starter motor that is loose and catching the ring gear, is that your car in the video ? That ones been on a rolling road and mapped, so it would be fair to assume the clutch has had some grief from the BHP increase.
  1. Golf GT TDi 150 Knocking noise
    By GKMVW in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2007, 04:18 PM
  2. Golf mk3 knocking noise - Driveshafts, CVs or engine mounts?
    By p1nke in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2007, 05:13 PM
  3. Golf knocking noise when pulling away? Engine mounts? Help?
    By spainy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-06-2007, 08:09 AM
  4. Knocking noise in engine
    By marathon in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-05-2007, 06:16 PM
  5. Golf - knocking noise in 4th & 6th
    By wasskies in forum Archive posts
    Last Post: 21-02-2007, 10:24 PM
