Thread: Fuses!
Results 1 to 9 of 9
  1. Fuses!
    May 2007
    I've just got a Passat 1.8t, but it looks like some fuses are missing? Heated mirrors what size amp would this be? I have manual and diagram inside cover but it does not state the ampere.
    Oct 2005
  3. Thumbs up
    May 2007
    Thanks that's well good, my first effort at this forum stuff!
    Oct 2005
    You're welcome and thanks for choosing us.
    Apr 2007
    Cumbria.
    Hi and Welcolme
    Please make sure your car has these "optional" extras actually fitted to the vehicle. All the fuse boards will be identical just with the extras ommited.
    It was broken BEFORE i touched it honest!
  6. Re: Fuses!
    Mar 2008
    and thanks form me too, have spent ages looking for the fuse index on the web, evan took quite a while to find it on here. now i have noticed that i pulled out the horn fuse and put it back in the wrong place, I can get the mot done!
    fuse location, fuse map, fuse index, fuse positions, just incase someone has the same problem i did
    Thanks again
  7. Re: Fuses!
    Oct 2005
    ^ Nice idea - I'll add some tags to make it easier to search - good lad and welcome to VWAF
  8. Re: Fuses!
    Sep 2008
    Birmingham
    Yes, very clever.
    Just thought, bet he's an avid Ebayer.
  9. Re: Fuses!
    niallyoc Guest
    Hey,
    This is a long shot and a thread hijack, so apologies in advance but I'm desperate!
    I have a problem with the boot motor / solenoid which is not working on my B5.5 Passat. I've connected the motor up to a 12V power supply and it appears to work fine. The problem seems to be that there is no power coming to the motor - both wires were at 0V when I tested the connector while pressing the release catch, so...
    Is there any fuse that is not listed above that could be causing this or does anyone know what else could cause this?
    I've traced the wire from the motor back into the boot by removing various pieces of trim and I didn't see any noticeable damage/cuts etc. I'd really appreciate it if someone could point me in the right direction!
    Cheers,
    Niall
  1. blowing fuses
    By majick in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-06-2007, 12:24 PM
  2. Fuses - '01 Passat GLS V6 -
    By minervini in forum Archive posts
    Last Post: 10-01-2007, 04:24 PM
  3. Fuses for golf
    By swgla1 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-12-2006, 01:13 PM
  4. Lupo fuses
    By stephanie in forum Polo - Derby - Lupo - Fox
    Last Post: 19-09-2006, 11:48 AM
  5. Window Fuses for 1.8T
    By Tearing Hair Out in forum Passat - Archive Topics
    Last Post: 24-07-2006, 05:25 PM
