Thread: Lupo fuses
  1. Lupo fuses
    I've just bought an x-reg Lupo and the windscreen washer doesn't work. Also, the lights for the heating dials doesn't come on when the headlights are on, although all the other dash lights work.
    I've tried to understand the fuses but to no avail. Does anyone have any advice about how to locate which fuse might have gone (the diagram on the fuse cover panel doesn't help!) or if there's another explanation for the failure.
    Thanks in advance for any help.
    the heater light fault will be the bulb The bulb is situated behind the centre control knob on the heater panel. Remove the knob using long nose pliers ( cove the knob with a piece of cloth to avoid damage). The bulb is beneath this. Remove the bulb without smashing it or you are F"*^ed ! Push in the new bulb and hey presto
    Check for a live and earth at the washer pump when operating the washer switch! The pump is probabely at fault though.
  1. Fuses!
    By tone70 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-10-2008, 01:47 AM
  2. blowing fuses
    By majick in forum TT - 8N Forum - 1998 - 2006
    Last Post: 08-06-2007, 12:24 PM
  3. Fuses - '01 Passat GLS V6 -
    By minervini in forum Archive posts
    Last Post: 10-01-2007, 04:24 PM
  4. Fuses for golf
    By swgla1 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-12-2006, 01:13 PM
  5. Window Fuses for 1.8T
    By Tearing Hair Out in forum Passat - Archive Topics
    Last Post: 24-07-2006, 05:25 PM
