Thread: Mudflaps + Suspension
Results 1 to 10 of 12
  1. Mudflaps + Suspension
    Hi guys,
    My passat compresses a fair bit over the bumps, and i am regularly hearing my flaps scrape the tarmac.
    The flaps are OE, the hard plastic type, and although it doesn't bother me them scraping, it does make me think my shocks/springs are a little on the soft side.
    Its a 'sport', and it passes the bump test on each corner, so it is a little surprising; am i just not used to driving a bigger barge?
    It does 'spring up' out of dips/compressions in the road as if the socks have had it compared to cars i am used to driving.
    Your thoughts please..thanks
    Regards
    Tom
  2. Re: Mudflaps + Suspension
    Oct 2005
    My 2001 SE had mudflaps. They scraped on everything and anything.
    When I lowered it, I managed to tear the rear ones off within minutes of leaving the driveway. I now just have the front mudflaps (to protect my paintwork
    It's normal, very annoying, but normal.
  3. Re: Mudflaps + Suspension
    Thanks and hi!
    Did you find your passat a little bouncy before you lowered it? I think thats the best way to describe it...
    Regards
    Tom
  4. Re: Mudflaps + Suspension
    Jul 2007
    Our 2001 Sport has dealer-fit flaps from new and dont ground out unless laden to silly limits (four adults, 60 bottles of wine, luggage for a fortnight crammed into every gap and a well-stuffed roofbox), and even with 130k plus on the original suspension doesn`t ground even over speed bumps.
    Might be worth finding a similar car and checking the ride height.
    The Sport shouldn`t be particularly bouncy, its a good deal firmer that the others, which I like (had a B5 SE before which made me seasick) but others think is too harsh, and they prefer the standard settings.
    You pays your money......
  5. Re: Mudflaps + Suspension
    SOMERSET
    I,too,have noticed my TDI highline grounding on the speed bumps in our road. I don't go over them too fast, but it does ground occasionaly. It doesn't seem to be load dependant either.
    This didn't happen with the A4 I had previously!
    Maybe I should go on that diet now...
  6. Re: Mudflaps + Suspension
    Aug 2007
    Hi my 01 sport flaps catch all the time and despite my best efforts they just won't come off just wish the rest of the car was built so well. Nige.
  7. Re: Mudflaps + Suspension
    likewise my b5.5 estate sport tdi fitted with vw plastic mudflaps also catches speed humps etc quite a lot, and also the front arch liner/undertray part catches aswell...car has standard suspension etc and only covered 33k...standard feature me thinks.
    B5.5 Torquetastic Passat Sport TDI Estate
    MK3 Golf GTi 8v
  8. Re: Mudflaps + Suspension
    Taunton
    My1999 tdi Sport grounds front and back!! Had it checked for clearance,all OK so now I just take it easy. So I guess it is normal..
  9. Re: Mudflaps + Suspension
    Ashbourne Derbyshire UK
    Has anyone tried a pair of spring assisters on the rear to stop it bottoming out ? I was thinking of trying some ?
    Once owned 98 1.8 ADR SE non turbo passat estate(The Mrs wrote it off)
    Now own 03 TDI 130 Sport 6 Speed passat estate
  10. Re: Mudflaps + Suspension
    Oct 2005
    Quote Originally Posted by grover View Post
    Thanks and hi!
    Regards
    Tom
    It was stable when fully laden but quite scary when you're on your own. In crosswinds it was like driving a blancmange.
  1. Suspension too low ?
    By Frank b in forum Passat - Archive Topics
    Last Post: 12-02-2008, 06:04 PM
  2. help...with suspension!!!
    By vw754 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2008, 01:14 AM
  3. Mk 4 GT Tdi suspension
    By Matt 1911 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-08-2007, 08:31 PM
  4. Suspension
    By danj1005 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-01-2007, 04:35 PM
  5. Suspension
    By Caribbeanwind in forum Passat - Archive Topics
    Last Post: 04-12-2006, 12:38 PM
