Thread: Rear LED tail light flicker weird!
Results 11 to 20 of 24
  1. Re: Rear LED tail light flicker weird!
    #11
    Feb 2009
    West Yorkshire
    10 Post(s)
    Check they are coded to highline. You have said they are standard led lights but we're they retrofitted. If so they will need recoding to prevent the bulb test feature of the ecu flashing them
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  2. Re: Rear LED tail light flicker weird!
    #12
    Begazzz Guest
    Hi sounds promising. I'll text the last owner and see if he fitted them. Can I ask if it's a simple job that main dealer wouldn't rip me off for doing or find an independant garage ( I'm nr barnstaple)
  3. Re: Rear LED tail light flicker weird!
    #13
    Begazzz Guest
    Previous owner says they are standard. Think I'll have to book it in somewhere
  4. Re: Rear LED tail light flicker weird!
    #14
    Feb 2009
    West Yorkshire
    10 Post(s)
    Surely there will be a member near you with VCDS who will scan it for you. The usual charge is free or a beer token or two. See Chris's signature for the list. Fraid I am in Yorkshire or I would have done it for you.
  5. Re: Rear LED tail light flicker weird!
    #15
    Begazzz Guest
    Yes I had a look and emailed one guy in barnstaple but no reply. There is a pretty good tech at the bosch centre so just going bite the bullet. Thanks all and if a fix is found I'll post it.
  6. Re: Rear LED tail light flicker weird!
    #16
    Leicester, United Kingdom, United Kingdom
    I had LED tail lights retro-fitted in my last 2006 A6 2.7tdi and the same thing occurred.
    This was being caused by the lamp failure sensing system generating pulses for filament lamps. The duration of these pulses are too short to illuminate bulbs with filament heaters, but long enough to trigger LEDs.
    At the time, my experience with VCDS was rather limited, so took it in to my local Audi dealer and they sorted it for an hour's labour charge.
    I hope this helps.
    2016 Audi A7 S-Line 272ps, Daytona Grey.
    Hers - 2011 Audi A1 1.4TFSI S-Tronic sport: supremely competent little car.
    Gone -
    2014 Porsche Panamera Diesel, 2006 A6 2.7tdi Q Avant, 2002 A6 2.4 Avant.
  7. Re: Rear LED tail light flicker weird!
    #17
    Begazzz Guest
    Hi. That's interesting. Wonder if the lights were retrofitted despite last owners insistence they were original. ? It was registered 1st aug 2008 in case there are any Led nerds out there
  8. Re: Rear LED tail light flicker weird!
    #18
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Begazzz View Post
    Best thing is to ring Audi parts dept at a dealer, give VIN and they should be able to tell you what it should have from factory.
    Also Audi Customer Care line can IIRC.
    PR Code 8SK = Taillight assemblies with diodes (LED) , usually not found on the data sticker in spare wheel well / service log but you could have a check. VAG systems should find this code associated with your VIN, if fitted from factory.
  9. Re: Rear LED tail light flicker weird!
    #19
    Nov 2012
    Somerset UK
    Always worth asking your local dealer for your 'car data' sheet, it's free and lists everything.
    My 07 is '8SK', although it is a saloon.
  10. Re: Rear LED tail light flicker weird!
    #20
    Feb 2009
    West Yorkshire
    10 Post(s)
    Quote Originally Posted by estwick View Post
    an hours labour for, no lies, a max of 10 minutes work. Sometimes Audi really let themselves down. Maybe it's a minimum charge. Maybe it's to pay for the showroom, I dunno
  1. Led rear tail light repair
    By mrmarc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-12-2015, 06:07 AM
  2. Replacing rear LED tail light cluster (failed LED bulb)
    By vw1967 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2013, 07:29 AM
  3. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  4. tail light - LED
    By snypa2k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2008, 09:45 PM
  5. Rear LED Tail lights
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-03-2008, 11:32 PM
