Thread: scan needed derby / burton on trent
  1. scan needed derby / burton on trent
    derbyshire
    hi all,i took a gamble and bought a 2006 passat estate, its a 1.9 diesel in vgc and very cheap.
    it was cheap for a reason, that reason is that there are about 5 warning lights on the dash, and also the handbrake switch flashes when used.
    i bought it thinking that it would be th erear calipers but before i start spending money i thought it best to get a scan.
    the car drives a1 and the brakes work fine,
    the previous owner said that he has had both calipers replaced by a mechanic who had a diagnostic kit
    what would a full scan cost,
  2. Re: scan needed derby / burton on trent
    Bradford
    Quote Originally Posted by jeepster1961 View Post
    a scan from a dealer is generally £50 to 80. A scan from a member via here will be hellofalot cheaper! Hopefully someone local to you will reply back to you.
  3. Re: scan needed derby / burton on trent
    Mar 2007
    Brum
    I'm based in Sutton Coldfield if you can't find anyone nearer. Will gladly do a full scan n clear what we can for you.
    Regards
    Scottiedogg
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  1. VAGCOM Help needed in Stoke-on-Trent or Staffordshire
    By tonyandkaty in forum VCDS - Users Locations
    Last Post: 22-12-2011, 06:34 PM
  2. scan needed
    By pem1 in forum VCDS - Users Locations
    Last Post: 12-06-2010, 09:34 AM
  3. help in burton on trent
    By audibigjohn in forum VCDS - Users Locations
    Last Post: 15-05-2009, 07:45 PM
  4. Please Help Wheel / Body Alignment Speciailist needed in Sheffield / Worksop / Derby Area Please
    By xouser8334 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2009, 02:48 PM
  5. Independent VW Servicing in Burton on Trent
    By David Bowman in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 22-05-2008, 08:08 AM
