Thread: Kept hold of the esp switch for 10 secs!!
Results 1 to 10 of 17
  1. Kept hold of the esp switch for 10 secs!!
    Jul 2008
    Bristol
    Hi all,
    As above, today I thought I will see what happens if I hold the esp switch for 10 secs, and straight after the light/sign dissapeared. I tried to press it again and the light would not come on.
    I then got abit worried, so I turned the ignition off and turned it back on again, luckily it went back to normal.
    Question is: What really happens when the ESP light dissappears after 10 secs?
  2. Re: Kept hold of the esp switch for 10 secs!!
    Nov 2009
    Cork
    Yes too, i read it on some reply in a forum somewhere. So i tried it going to work in the morning... got a little worried when it didn't come back on ( realised until i restarted )
    AUDI A4 Avant 2.0TDI S Line
    | My Slipper |
  3. Re: Kept hold of the esp switch for 10 secs!!
    May 2010
    Newcastle, UK
    I've seen this on the ESP systems of Mercs before. I don't know what the purpose is? But it's a fairly common thing.
  4. Re: Kept hold of the esp switch for 10 secs!!
    Mar 2010
    notts u.k
    Quote Originally Posted by Zeb View Post
    Hi all,
    Answer When you hold the button in it disables the ESP so you are driving the car with no traction control it will reset back when you turn the ignition off and back on
  5. Re: Kept hold of the esp switch for 10 secs!!
    2018 Post(s)
    All control of ones bowels is lost...
  6. Re: Kept hold of the esp switch for 10 secs!!
    Jun 2006
    UK, Mids
    I should imagine it sets an error code about the switch being faulty and disables the system until a restart.
    Audi A8 - 2015 - 3.0TDI
  7. Re: Kept hold of the esp switch for 10 secs!!
    Jan 2006
    PRESTON, LANCS
    Hi all,
    As the saying goes -'idle hands'- etc .
  8. Re: Kept hold of the esp switch for 10 secs!!
    Jul 2008
    Bristol
    Quote Originally Posted by pete99 View Post
    - Cooool!!!
  9. Re: Kept hold of the esp switch for 10 secs!!
    Dec 2006
    Quote Originally Posted by snapdragon View Post
    Thats what it will do,
    On the A4 you are unable to turn off all driving aids,
    I think when the Traction control is off, the element of the ESP still stays in force..
    This can be disabled via vag-com though
  10. Re: Kept hold of the esp switch for 10 secs!!
    Sep 2009
    London, England
    I have got a problem regarding the ESP switch, as I drive along sometimes the light comes on but when I try to switch it off it doesn’t work. Also sometimes it might come on and off by itself? I don’t think that this is normal, is it? Can anyone help..
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. front fogs
    By paulsa4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-12-2010, 08:06 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. Can I switch auto hold on as default?
    By badgerman26 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2009, 11:40 AM
  5. How to remove ESP switch?
    By davidrc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-02-2008, 09:46 PM
