Thread: Bluetooth blackberry curve problem
Results 1 to 10 of 13
  1. Bluetooth blackberry curve problem
    Nov 2008
    i have a new blackberry curve & a new audi a4 . I can connect the two together but it won't transfer the contacts ! I just get an object push error, can anyone tell me how to get round this ?
    thanks
  2. Re: Bluetooth blackberry curve problem
    Mar 2009
    London, UK
    Do you have Bluetooth High or Low?
    If you have high, try connect the car to the phone, rather than the phone to the car if that makes sense!
    Kavi
  3. Re: Bluetooth blackberry curve problem
    Nov 2008
    whats high ?
    my car has the low i think.
  4. Re: Bluetooth blackberry curve problem
    Dec 2007
    London/Surrey
    -switch the ignition on
    -make sure the handsets bluetooth is on
    -On the blackberry; MENU > MANAGE CONNECTIONS > scroll down to BLUETOOTH OPTIONS > (make sure the bluetooth is on!) > press the menu button on the blackberry to get options > ADD DEVICE > SEARCH.
    -The search should automatically find the AUDI ****
    -Pair the 2 devices, the passcode is 1234.
    -Once the connection has been established, it can take a bit of time to add the phone book list to the car...so be patient. Message PLEASE WAIT will appear.
    -Once that is done, your set to go!
    -Use the thumbwheel and buttons to make/receive calls. ETC! Errors appear when these thumbwheel buttons, the mode buttons are pushed.
    If the contacts arn't going onto the cars phone book, then make sure your contacts are SAVED TO SIM on the handset.
    COMING SOON: '14 A5 Cabriolet S-line Special edition, Daytona Grey
    CURRENT: 11' A5 S-Line Black Edition Ibis White
    previous: 09' A3 S-line Ibis White
  5. Re: Bluetooth blackberry curve problem
    Nov 2008
    Quote Originally Posted by tlionhart View Post
    thanks just tried your procedure.
    The phone connects up to car ok,
    I can see my numbers dialed list & names
    When i go to the phonebook It says no entries found.
    When I go to recieved calls it just shows me numbers not names.
    I have 750 numbers in my black berry memory so they won't fit on the memory card.
    I have the car phone setting set to sim,tel for the memory usage.
    I am totally puzzled by this. I have read every forum possible to try to solve this, the car does not even look like it is getting any numbers from the phone.
  6. Re: Bluetooth blackberry curve problem
    Feb 2009
    I have the same phone and a month old Avant SE with phone prep low. I can confirm it does work but takes while for the contacts to appear on the screen.
    I cannot manually upload to the car [object push error] but within a minute or so after getting in the car the phone book menu becomes available on the dash screen.
    My blackberry is a silver 8300 curve on O2.
    Does this help?
    MY09 A4 Avant SE 1.8 TFSI 160 Manual - Meteor Gray - Phone Prep Low - AMI - Hill Hold Assist - Park Assist
  7. Re: Bluetooth blackberry curve problem
    Nov 2008
    Quote Originally Posted by Nano Jake View Post
    Does this help?
    My bluetooth is totally confused the phone book never appears, the last dialed numbers are utter nonsense with people i dialed 2 months ago.
    need to get this fixed soon
  8. Re: Bluetooth blackberry curve problem
    Quote Originally Posted by jonathon555 View Post
    They are in chronological order. However the oldest numbers dialled are at the top of the list, and the most recent are all the way down the bottom of the list.
    Its a bit backward, I agree, but FYI: Thats how it works.
  9. Re: Bluetooth blackberry curve problem
    Kj5cott Guest
    Gents, I have had the same problem in the past and have spent nealry a year trying to get an answer from Blackberry and Audi. Good news is I;ve got the solution.
    To ensure the contacts transfer to the phone book as displayed in the MMI screen do the following;
    1. With your audi turned on and connected via bluetooth, disconnect and delete the pairing.
    2. Switch your audi off ensuring the ignition is off too.
    3. On you blackberry look at your email screen and hit the menu button and and select "view folder"
    4. Scroll down and select "phone call logs"
    5. Whilst holding the shift key scroll down to select all entries then delete them
    6. Repeat step 4 & 5 but select "missed calls" instead of phone call logs
    7. Now repair the blackberry with your audi.
    8. Viola, the phone book will transfer.
    The rationale for this fix is that the Blackberry memory stores all calls in a seperate part of its memory. if you delete the call logs from the phone screen i.e. when you select re-dial, this does not delete the items from the main "hidden" memory. The Bluetooth function tries to push the contacts from the "hidden"memory but becomes blocked due to its size. If you have not cleared the "hidden" memory in this way before you can have up to 9 months of call data stored in it which is too much for the bluetooth to handle.
    Hope this helps, let me know how you get on and remember to clear the hidden memory every few months.
    Kevin
  10. Re: Bluetooth blackberry curve problem
    Mar 2009
    London, UK
    Quote Originally Posted by Kj5cott View Post
    Kevin
    Kevin, I reckon you meant VOILA...... not viola (a small violin!)
  1. HELP!!!pair blackberry vs wv premium bluetooth
    By ilradi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-08-2010, 12:37 PM
  2. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  3. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  4. Help! Clicking window problem.
    By dcorcouk in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-03-2008, 09:58 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
