Thread: Juddering on idle
Results 1 to 10 of 28
  1. Re: Juddering on idle
    I get a bit of random vibration at idle occassionaly, as if it's not idling properly, and look down expecting to see some movement on the rev counter, but it's as steady as a rock.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  2. Re: Juddering on idle
    May 2009
    Essex
    I guess the only way to check whether it idleing properly is to hook it up to vag com or something? I don't reallly want to pay VW to do this. The symptoms are exactly the same as described in other posts above.
    Thanks for your help everyone.
  3. Re: Juddering on idle
    Norfolk
    If the duel mass flywheel is on the way out it can put the whole engine out of balance so it seems to shudder on tickover. If this was the problem you would feel it through the clutch as you went to pull away in first gear.
  4. Re: Juddering on idle
    May 2009
    Essex
    Thanks, can yuo describe what I might feel on the clutch on pull away?
  5. Re: Juddering on idle
    Norfolk
    Quote Originally Posted by joey1002 View Post
    Let clutch up very gently in first gear. You will feel it engage. If you feel a second bump as if the clutch is engaging twice, that is play in the dual mass flywheel. If you drive smoothly they can last for ages like that. You can sometimes hear this as a sort of chattering noise from the engine at idle.
  6. Re: Juddering on idle
    May 2009
    Essex
    Thanks very much for your help, I will try the test later.
  7. Re: Juddering on idle
    Oct 2005
    I`d been having the juddering issue, then last Friday I went out at lunch time - to see my mechanic as it goes - and when I tried to start her again, just kept turning, took ages to get it going and felt like it was going to cut out whenever I stopped. hardly any power and really lumpy driving, so dropped it off at Liverpool VW Friday evening, and just found out that it needs 4 new injectors.
    Glad I took out my extended warranty 3 months ago.
  8. Re: Juddering on idle
    Jan 2009
    just had my dmf and clutch changed and mines stoped juddering vw said theres a problem with some dmf
  9. Re: Juddering on idle
    Derry
    Quote Originally Posted by Stuart W View Post
    I get the same thing too Stuart. I think it may be a VAG engine trait, as my friend's 1.2 Polo does the same thing.
    2006 B6 Passat 1.9TDi 105 | 35k | Deep Black Pearlescent | 18" OZ Superturismo Rims | Chrome Grill | 35% Tinted Rear Windows | Boot Lip Spoiler | Debadged
  10. Re: Juddering on idle
    May 2008
    I know of several Golfs that have had the dual-mass flywheel changed due to this. Our DSG Passat is doing this also now in the first 5 or so seconds after starting the engine and it's worse when the engine's cold. I mentioned it to the dealer who said they couldn't find anything but I will be pushing it again before the warranty expires in June.
  1. re Fast Idle persists after TBA etc Polo 1.0l
    By patrickLL in forum VCDS - Help Requests
    Last Post: 23-04-2009, 02:10 PM
  2. 03 Polo 1.4 FSI Juddering when idle
    By lpdkill in forum Polo - Derby - Lupo - Fox
    Last Post: 04-05-2008, 04:19 PM
  3. Erratic idle A4 Quattro - 1995- 2.6
    By JDA in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2008, 07:49 PM
  4. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
