Thread: Engine replacement advice
  1. Engine replacement advice
    Mar 2019
    Canada
    My son needs a new engine in his 2007 8P 6MT 2.0T and we're looking for a suitable direct replacement.
    Coming from an A4 2.0T (Quattro B7) myself, I know that an engine that originally came with a CVT won't work with my gearbox as the crank output shaft won't mate with my gearbox.
    Is this the same story with the 8P 6MT vs 6AT? Or will we be fine buying an engine that came from a 6AT?
    Sent from my IN2025 using Tapatalk
  2. Re: Engine replacement advice
    2009 Post(s)
    If it is from a DSG, you need to add an input shaft bearing 056 105 313 C
  3. Re: Engine replacement advice
    Mar 2019
    Canada
    Thanks, Crasher. This is good info. So from what I can find online, it's looking like in Canada where I'm at, these cars came in 6MT or 6AT DSG with paddle shifters. So I'll likely need this bearing.
    In case I'm finding bad info, will the VIN tell me if the car came with a DSG? If so, I can just look up the VIN from the engine I'm buying.
  4. Re: Engine replacement advice
    2009 Post(s)
    You need a subscription based commercial system to use the VIN, what is it?
  5. Re: Engine replacement advice
    Mar 2019
    Canada
    Here is the VIN from the donor engine:
    WAUHF68P08A116744
    Sent from my SM-F966W using Tapatalk
  6. Re: Engine replacement advice
    2009 Post(s)
    That is a BPY DSG engine and I typed it the wrong way around, the DSG needs the bearing, manual doesn't and it is a good idea to extract the bearing as the roller can fall out.
    Looking at the time I posted it makes sense
  7. Re: Engine replacement advice
    Mar 2019
    Canada
    Thanks again! Cheers, Crasher!
  1. Question Gearbox replacement advice please
    By Stu84 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 02-09-2019, 01:20 PM
  2. Engine replacement advice, 2005 Audi A4 2.0tfsi quattro BGB
    By skyegtb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2017, 09:35 PM
  3. Engine replacement advice, 2005 Audi A4 2.0tfsi quattro BGB
    By skyegtb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-03-2017, 09:28 PM
  4. EGR Valve replacement advice.
    By midge6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-04-2011, 10:57 AM
  5. Please Help 115 tdi pd engine blown, advice please on replacement engine.
    By glyndwr1998 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 01:37 PM
