Thread: 115 tdi pd engine blown, advice please on replacement engine.
Results 1 to 10 of 13
  1. 115 tdi pd engine blown, advice please on replacement engine.
    Sep 2009
    aberdare
    Hi, my engine has just blown, bottom end had gone, it had done 180,000 miles so cant complain.
    The engine is a 115 bhp pd type engine from a w reg year 2000 passat. The engine is a code ATJ.
    I am looking for a 2nd hand engine, is there any other code engine that will fit and run ok with the ecu in this car. I have seen a few 130 engines, but not sure if they will work in my car.
    Any help would be greatly appreciated, even of the engineis out of a seat, audi or vw (even the galaxy) just want to try to broaden my search to get a reasonalbt priced 2nd hand unit.
    Many thanks for your help.
    best regards, glyndwr1998
  2. Re: 115 tdi pd engine blown, advice please on replacement engine.
    Gwent
    This probably has the same lump as yours?
    http://cgi.ebay.co.uk/volkswagon-pas...item4cefa433d0
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: 115 tdi pd engine blown, advice please on replacement engine.
    Sep 2009
    aberdare
    Thaks for that bud,
    unfortunately, already contacted the seller, engines not available whole, only in bits.
    Any other ideas as to what engine codes will fit and work in my model pasat.
    I have read that the ajm engine is suitable. Can anyone confirm this.
    many thanks.
  4. Re: 115 tdi pd engine blown, advice please on replacement engine.
    7 Post(s)
    I'd try and get a 130hp engine for it. Look for an AWX engine code.
    That would mean you'd need the ecu and clocks as well though.
    The 115hp engines being the first PD's are not that relieable and usually suffer from head gasket failure which means that 2nd hand they are quite rare.
  5. Re: 115 tdi pd engine blown, advice please on replacement engine.
    Sep 2009
    aberdare
    Thanks bigcol,
    I`d like to try to get the correct unit for it if i can, without changing the ecu maf etc...
    Its difficult out there to get a 2nd hand unit, may have to strip and repair mine, but dont really want to.
    Thanks, any other ideas, or anyone know of a breaker or seller selling one let me know...
    Cheere.
  6. Re: 115 tdi pd engine blown, advice please on replacement engine.
    DSG4ME Guest
    Break it and buy another car mate, cheaper and hassleless option.
  7. Re: 115 tdi pd engine blown, advice please on replacement engine.
    Sep 2009
    aberdare
    Your probably right bud, anything between 500 - 1000 pound for an engine, 2nd hand passat anywhere around 1000, something i`ll have to consider.
  8. Re: 115 tdi pd engine blown, advice please on replacement engine.
    DSG4ME Guest
    Quote Originally Posted by glyndwr1998 View Post
    Or look for an MOT fail cheap that has a good lump in it, most times it's better to buy the whole car rather than parts, personally I'd write it off at that mileage and let someone else tinker with it, or you could have the bottom end re-done, how bad is it, if the bores are ok you can get away with shells,rings and a crank grind, if it's thrown a rod things get a bit more complicated then, if it's simply knocking, shells and a grind should do it, and ignore garages, go to a machine shop once you know what sizes you need.
  9. Re: 115 tdi pd engine blown, advice please on replacement engine.
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by BigCol View Post
    Now Colin, I hate to disagree with you, however having had a 115bhp ATJ and running it up to 227k without any issues, as long as they are serviced regularly, I'd say they were no more unreliable than the 130bhp lumps. I still wish I had mine (stupid women drivers.....)
    Nothing to see here, move along..
  10. Re: 115 tdi pd engine blown, advice please on replacement engine.
    Aug 2007
    I am not saying it would be economic but there are a number of ATJ engines on ebay in Germany (www.ebay.de)
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  4. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  5. Replacement TDI engine
    By j_coupland in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-03-2006, 05:42 PM
