Thread: Leon MK3 1.4 tsi 150 clutch judder
  1. Leon MK3 1.4 tsi 150 clutch judder
    Sep 2016
    I have a 2016 Seat Leon with the 1.4 TSI ACT engine CZEA and have been experiencing a judder when at biting point intermittently for almost a year and a half now. It occurs for me when the car is fully warmed up after a while of doing city driving - so a lot of clutch use. Although sometimes it will do it first thing in the morning. The judder can be quite severe making the car shake a lot but strangely on some days it can be completely fine! Apart from this, the clutch seems good, no slipping, no other issues. Mileage is 65k and I do like the car but thinking is it worth doing a clutch/flywheel replacement?
    Doing some reading around on forums, it seems to be a common issue with this engine on the A3 too, so I'm wondering if there is a known cause.
    By the way, I did some digging and LUK do an aftermarket clutch kit which is part no. 623308200 and the flywheel 415094810. Wondering if anybody here can confirm if this is correct. The flywheel is out of stock everywhere at the moment however.
  2. Re: Leon MK3 1.4 tsi 150 clutch judder
    Sep 2016
    Bump - hoping Crasher sees this
  3. Re: Leon MK3 1.4 tsi 150 clutch judder
    2009 Post(s)
    What is the VIN?
  4. Re: Leon MK3 1.4 tsi 150 clutch judder
    Sep 2016
    What is the VIN?
    I have private messaged you the VIN. Thanks.
  5. Re: Leon MK3 1.4 tsi 150 clutch judder
    2009 Post(s)
    We would fit the full LUK set 600 0169 00. With the box out a release fork, guide sleeve and pivot bolt may be required. The flywheel is revised.
  6. Re: Leon MK3 1.4 tsi 150 clutch judder
    Sep 2016
    Thanks. On PartsinMotion website that kit is showing as incorrect for my car?
  7. Re: Leon MK3 1.4 tsi 150 clutch judder
    2009 Post(s)
    Using Partslink24, the pressure and friction plate kit is 04E 141 015 K, the release bearing 02A 141 165 R and revised flywheel 04E 105 266 N. The basic LUK kit listed by Tec Doc is 623 3082 00 and the flywheel on its own 415 0948 10 and the flywheel is the conflict point. This often happens with LUK and you often have the supplier running back and forth trying to get the right parts. I think I would go for the basic kit, plus flywheel and order the sleeve and release bearing separately. If we see a conflict like this, we usually get the supplier to work it out.
  8. Re: Leon MK3 1.4 tsi 150 clutch judder
    Sep 2016
    Thanks Crasher. Like I said earlier the LUK flywheel on its own is out of stock everywhere so I’ll hold off for now. I’m wondering why the issue is intermittent maybe there’s some hot spots on the flywheel?
    What can I expect to pay labour wise? I would be happy with £700-800 all in including parts.
  9. Re: Leon MK3 1.4 tsi 150 clutch judder
    Aug 2024
    Berlin
    Quote Originally Posted by tempz287 View Post
    Hey tempz. Mine is Passat b8 1.4 TSI with same engine code and parts number as yours. You are right the Luk flywheel is not available in the whole world 😓 , I emailed Shaffler almost 3 months ago ,they replied it should be available in week 32. Unfortunately nothing came out. Original just flywheel cost 950 + others parts + labour. Man I got caught with this engine. Did you found any solution yet. Glad if we share info. I am from Berlin
  1. 2.0 TDi Clutch judder.
    By thedktor in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-05-2021, 07:22 AM
  2. Please Help intermittent clutch judder with new clutch & flywheel
    By FLENG2008 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2013, 03:48 PM
  3. clutch judder
    By jamedvickni in forum Golf MK5 - 2004 - 2009
    Last Post: 07-12-2009, 03:22 PM
  4. Clutch judder
    By redkite66 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-10-2009, 11:17 AM
  5. Clutch Judder
    By stupotads in forum New Member Introductions
    Last Post: 04-04-2008, 02:29 AM
