Thread: C6 Brake Master Cylinder Location
  1. C6 Brake Master Cylinder Location
    Dec 2007
    Oxford UK
    I must be a total numpty but I can't find the master cylinder on my 2008 2.0TDI C6 Avant!! Should be accessed through the 'apron' at the rear of the engine bay but whereas the manual shows the plastic grille cut away revealing the yellow filler cap there is no cutaway and no access through the 'apron'
    Any one else's gone missing?!
  2. Re: C6 Brake Master Cylinder Location
    2021 Post(s)
    You have to take the plenum chamber cover off
  3. Re: C6 Brake Master Cylinder Location
    Dec 2007
    Oxford UK
    Once more in English please...
  4. Re: C6 Brake Master Cylinder Location
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Gorepe15 View Post
    The "Apron" you're referring to is the plastic cover of the plenum chamber below the windscreen. You need to remove the "apron" to get to the master cylinder - that's what Crasher means.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  5. Re: C6 Brake Master Cylinder Location
    2021 Post(s)
    The big flat palstic thingy...
  6. Re: C6 Brake Master Cylinder Location
    Dec 2007
    Oxford UK
    Thanks.. my history in aeronautical engineering has plenum chambers down as vessels used for holding pressurised gases rather than a hole for hiding critical service items!
    Found the brake master thanks, the handbook and every video on Youtube shows a cut out in the cover so , as the handbook says, you can check the fluid level 'at a glance' Not having to take big bits of car off!
    Thanks again for your help
  7. Re: C6 Brake Master Cylinder Location
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    "The plenum chamber is a chamber located in front of the windshield, where air pressure is above atmospheric. It provides a volume of air which is drawn into the car from the chamber through the heater, air-conditioner or vents." Part of the HVAC.
  1. Please Help Brake Master Cylinder
    By robj20 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-02-2016, 09:37 AM
  2. B6 Brake master cylinder removal
    By alexf2828 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-05-2015, 08:59 PM
  3. Brake master cylinder
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-04-2010, 07:45 PM
  4. Question Master Brake Cylinder
    By Kitten in forum Golf MK4 - 1999 - 2004
    Last Post: 27-01-2010, 10:46 PM
  5. Brake Master Cylinder ?
    By Adam in forum Archive posts
    Last Post: 05-09-2006, 09:16 PM
