Thread: Slacken bolts for camshaft sproket? A3 8p 2.0 140
Results 1 to 10 of 10
  1. Question Slacken bolts for camshaft sproket? A3 8p 2.0 140
    Jun 2019
    Finistère, France
    Hello all,
    I am soon going to do my timing belt, water pump and rollers on my 2011 A3 Sportback, 2.0 140 engine code CFFB. Reading the manual and forums they say that you have to loosen the cam sproket and high pressure pump sproket when locked in place to be able to rotate them slightly.
    I would really appreciate it if somebody could explain why? Surely if you remove a toothed belt, refit the exact same thing, nothing should change?
    Or maybe it is just to make the removal, install easier.
    I don't know, but love to know as much as possible before doing a job and if I could know the "science" behind these loose sprockets I would be a happy chap.
    Thanks in advance guys
  2. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    131 Post(s)
    1978 Post(s)
    It is to take into account fractional differences between belts so allow in the the tooth spacing between all three points to be optimised and any slack taken up by the tensioner.
  3. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    Jun 2019
    Finistère, France
    Thank you for your reply, so I better loosen them when doing my timing then. Fingers crossed there will be no valve timing issues
  4. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    131 Post(s)
    1978 Post(s)
    Remember that the idler nut and stud, tensioner nut and stud, pump roller bolt and pump sprocket bolts are one time only Torque To Yield and MUST be replaced with the correct specification fastener.
  5. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    Jun 2019
    Finistère, France
    I ordered a Gates KP25649XS-1 kit that seems to have all the bits needed, all will be swaped out. If you don't mind could you give me the torque specs please? I have been seeing different values all over.
  6. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    131 Post(s)
    1978 Post(s)
    1 - Toothed belt
    2 - Idler roller
    3 – Nut, Renew, 20 Nm
    4 – Stud, Renew, 15 Nm
    5 – Nut, Renew, 20 Nm + turn 45° further
    6 - Tensioning roller
    7 – Stud, Renew, 15 Nm
    8 – Bolt, 20 Nm
    9 - Idler roller
    10 – Bolt, 25 Nm
    11 - Camshaft sprocket
    12 – Bolt, Slacken and tighten with counter hold tool -T10051-, 100 Nm
    13 - Camshaft hub
    14 - Plug
    15 - Toothed belt cover (rear)
    16 – Bolt, 9 Nm
    17 - High-pressure pump hub
    18 – Nut, 95 Nm
    19 - High-pressure pump sprocket
    20 – Bolt, Renew, 20 Nm
    21 - Idler roller
    22 – Bolt, Renew, 50 Nm + turn 90° further
    23 - O-ring, Renew
    24 - Coolant pump
    25 – Bolt, 15Nm
    26 - Crankshaft sprocket, Contact surface between sprocket and crankshaft must be free of oil
    27 – Bolt, Renew, Slacken and tighten with counter hold tool -3415- Do not additionally oil threads and shoulder
    Tighten in three stages as follows:
    1st stage: 180 Nm
    2nd stage: Use rigid wrench to turn 90° further
    3rd stage: Use rigid wrench to turn 45° further
    Toothed belt cover, Tighten bolts to 9 Nm.
    0 3 0
  7. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    Jun 2019
    Finistère, France
    You are a star ! Thank you so much for your time and help
  8. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    May 2020
    london
    1 - Toothed belt
    2 - Idler roller
    8 – Bolt, 20 Nm
    9 - Idler roller
    10 – Bolt, 25 Nm
    13 - Camshaft hub
    14 - Plug
    16 – Bolt, 9 Nm
    18 – Nut, 95 Nm
    21 - Idler roller
    23 - O-ring, Renew
    24 - Coolant pump
    25 – Bolt, 15Nm
    26 - Crankshaft sprocket, Contact surface between sprocket and crankshaft must be free of oil snaptube
    27 – Bolt, Renew, Slacken and tighten with counter hold tool -vidmate- Do not additionally oil threads and shoulder
    1st stage: 180 Nm
    I was looking for this, Thanks for helping!
  9. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    Mar 2010
    Derry ireland
    66 Post(s)
    If your timing is ok before you re-place your timing belt do not slacken camshafts bolts as long as you have the proper timing tools your belt will slip on & tension up ok
  10. Re: Slacken bolts for camshaft sproket? A3 8p 2.0 140
    Jun 2019
    Finistère, France
    Quote Originally Posted by elitclark View Post
    We are lucky to have a human encyclopedia like Crasher around !
  1. Struggling to align camshaft sprokets holes with TDC Camshaft
    By Josana in forum Chat - Anything with wheels
    Last Post: 10-09-2022, 10:18 AM
  2. Replies: 3
    Last Post: 18-10-2012, 09:46 AM
  3. Question Bolts for brake caliper '7mm Hex bolts'
    By geoff eeles in forum Golf MK4 - 1999 - 2004
    Last Post: 01-08-2012, 07:59 PM
  4. Big End Bolts Again
    By marshp in forum Golf MK3 - 1993 - 1999
    Last Post: 17-08-2008, 08:59 PM
  5. Do you have to slacken handbrake when changing pads?
    By Rog in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2007, 01:09 PM
