Thread: Efficiency Drive Select Mode
  1. Re: Efficiency Drive Select Mode
    Oct 2019
    Bridgnorth, United Kingdom
    Quote Originally Posted by ragebe View Post
    I do most of my mileage in Efficiency Mode and it always shows as E. I think you've been fobbed off.
    Sent from my SM-G965F using Tapatalk
    Which year is your Q7, I read on another post here that it seems to be later ones that have had the problem.
  2. Re: Efficiency Drive Select Mode
    New Forest
    80 Post(s)
    Quote Originally Posted by si_b View Post
    Mine is 2016. I've checked it a couple of times today, since my initial reply and on each occasion, starting was with the letter E, on the display.
    I've also updated my MMI software to 0976 (or similar) which I believe to be the latest flavour, so I'm not sure it would be a software error causing this for you.
    Might be worth a read of the manual (or popping the manual CD in a laptop for a faster search)?
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  3. Re: Efficiency Drive Select Mode
    Jan 2018
    Warsaw
    65 Post(s)
    It is normal in new models. I have checked it also in Owners Manual. After switching on the engine again the gearbox will be always in "D" mode. It concerns not only Efficiency Mode but Dynamic Mode as well. I don't have an idea what is the rational behind this.
  1. What Mode Do You Use in Drive Select & Why?
    By rapport25 in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 09-10-2019, 06:47 AM
  2. Drive select help please
    By Monktopus in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 31-08-2018, 10:58 AM
  3. Drive Select - Efficiency
    By DiScO197 in forum Q7 - 4M Forum - 2016 -
    Last Post: 22-07-2018, 07:57 PM
  4. Drive select mode in the snow
    By GEAudi in forum Q7 - 4M Forum - 2016 -
    Last Post: 11-12-2017, 05:23 PM
  5. DPF and Efficiency mode
    By nealeb in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-02-2012, 09:31 PM
