Thread: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
  1. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #31
    Jan 2009
    Derby
    Thanks to a couple of really good posts on here, and B5NUT answering a couple of questions for me, I decided to go for the AMI and DAB retrofit.
    I bought a DAB radio module 4F0 035 061 B for ebay.de for £140, then bought the amplifier (4F9 035 225 S), 3 pin connector (1C0 983 119 B), captive nut (WHT 000 011) and screw (N 106 569 01) from Audi, along with a couple of repair wires, all of which cost me £55.91. I then bought a 6m cable with Fakra connectors to connect the radio module to the amplifier from Car Electronics on Ebay for £10.
    I bought the AMI wiring loom from Kufatec in the end, for £175, and got the glovebox trim from Audi for around £5. I still need to get the AMI iphone cable yet, so looking round for a good deal.
    Following this thread - VW Audi Forum - The #1 VW Group Community - I started by removing the interior trim I need to take out in order to run the cabling, and install the amplifier. As I didn't fancy soldering the wiring to the window, I bought some conductive paint but I just couldn't get on with it at all, too thin and was taking way too long to dry. So for the time being I have gaffer taped the cable conductors to just test that everything works, and will look for another solution.
    I then took out my old radio unit, fitted the DAB radio unit, and connected up the 3 existing connectors and the new DAB amplifier connection. I turned the ignition on to see whether it had worked. I could now select DAB, and there was a huge list of DAB stations, but no audio. So I took the car to my friends garage as he has VCDS and borrowed his laptop. I enabled digital radio in the application list, but still no joy. I did a full scan and got the following:
    hursday,08,September,2016,16:50:54:55487
    VCDS Version: 16.8.1.3 (x64)
    Data version: 20160902 DS256
    Ross-Tech: Home
    VIN: WAUZZZ4F7BN071876 License Plate:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 08 09 0E 0F 15 16 17 19 42 46 4F 52 53 55 56 5F
    62 72 76
    VIN: WAUZZZ4F7BN071876 Mileage: 174060km-108155miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    0F-Digital Radio -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    5F-Information Electr. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    And the relevant fault codes:
    Address 0F: Digital Radio
    Cannot be reached
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L113058029
    Coding: 000303
    Shop #: WSC 02391 823 56573
    VCID: 3979D9BEB0812D8AA9-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    Serial number: 00000000002790711947
    2 Faults Found:
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 180
    Mileage: 174061 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 15:03:49
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 11.60 V
    Count: 7
    Text: FF30746C20023100
    (no units): 29688.0
    (no units): 49.0
    02230 - Digital Radio (DAB) (R147)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 174066 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 16:36:11
    Freeze Frame:
    Bin. Bits: 10111
    Voltage: 11.90 V
    Count: 7
    Bin. Bits: 10011
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4F0 035 061 H HW: 4F0 035 061
    Component: Radio U DAB H45 0048
    Revision: AB001007 Serial number: 343H$097527664
    Coding: 010105010000000002
    Shop #: WSC 06443 128 28888
    VCID: 214911DE3811554A81-8074
    2 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 174061 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 15:02:56
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 219
    Mileage: 174061 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 15:02:56
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 666 H HW: 4E0 035 666 C
    Component: H-BN-EU H51 0174
    Revision: -------- Serial number: 454CX0B7583260
    Coding: 010101010002C3ED01000315EF6300030001
    VCID: 2B55F3F64ADD8F1A2B-807E
    Subsystem 1 - Part No: 8R0 060 884 N
    Component: EUR 2011 1205
    Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
    Component: DU7 High H43 0098
    Serial number: 9466C-0B0546169
    Subsystem 3 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 M
    Component: Bedienteil MM H01 0060
    Serial number: 00000001804936
    Subsystem 4 - Part No: 8R0 060 961 A
    Component: CD-Database 2712
    3 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 174066 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 16:35:21
    Freeze Frame:
    Voltage: 12.40 V
    00384 - Optical Databus
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 220
    Mileage: 174066 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 16:33:17
    Freeze Frame:
    Voltage: 12.70 V
    00822 - Connection DSP to Radio
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 180
    Mileage: 174066 km
    Time Indication: 0
    Date: 2016.09.08
    Time: 16:35:24
    Freeze Frame:
    Voltage: 12.60 V
    So for the time being I have connected the old radio unit up until I can try and work out what's going on. The component protection codes I was expecting, but not the others, so I need to do a bit of research.
    The AMI I have still yet to fit.
    Thanks for reading.
    2011 (61) Audi A6 Avant 3.0 TDi Quattro Special Edition - Quartz Grey
  2. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #32
    May 2014
    Darlington
    78 Post(s)
    The coding on the AMP is wrong the internal amplifier is disabled so you won't get any sound, try this coding 01010302010000000000. Also component protect is enabled this could also cause problems, if it does then you need to visit your local Audi dealer and get it removed.
    Also remove 0F from the gateway, that is the old DAB 2G module.
    Use this page to help remove the "03276 - Please Check Software Version Management " on the 5F module
    Once you have done all that clear all the fault codes and you should be all fixed.
  3. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #33
    Aberdeen
    63 Post(s)
    I've got an AMI cable if you want. It's got the Lightning connector and a white collar. I'll try and remember and get the part number from it or PM me for details and photos.
  4. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #34
    Jan 2009
    Derby
    Quote Originally Posted by B5NUT View Post
    Thanks, I was planning on visiting the dealer today to see if they would help with the CP - spoke to the service desk on the phone who didn't have a clue what I was talking about. I will remove 0F later this morning. Do I need to enable digital radio anywhere else?
  5. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #35
    Jan 2009
    Derby
    Quote Originally Posted by Scott K View Post
    That would be great, thanks - I think the part number I need is 4F0 051 510 AE which I am told is the white collar cable with lightening connector.
  6. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #36
    May 2014
    Darlington
    78 Post(s)
    No. Just code the radio module correctly. You may have to power cycle the radio to enable the AMP.
  7. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #37
    Jan 2009
    Derby
    Thanks - I put the coding in as you suggested and now I have audio that intermittently cuts out. I guess this is down to the component protections and explains the fault codes which have intermittent against them.
  8. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #38
    Jan 2009
    Derby
    I have contacted my local Audi dealership today who have told me they will have nothing to do with removing component protection from 2nd hand units, so I have booked the car in to my local specialist, but I couldn't get it in until next Friday unfortunately.
  9. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #39
    Jul 2013
    77 Post(s)
    Get a set of firmware disc and perform an update if the DAB needs an update then this will get the DAB working correctly, the CP code will be still there but everything will work.
    If the DAB cannot be updated then you need an authorized specialist to remove the CP.
    i have just upgraded my radio to OEM 3G DAB and the firmware trick worked for me.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  10. Re: 2011 Audi A6 Avant 3.0 TDi Quattro Special Edition
    #40
    Jan 2009
    Derby
    Thought I better update this...
    I managed to complete the DAB install and everything is working as it should now. The local Audi dealer would have nothing to do with removing the CP, but fortunately the local specialist was able to do it.
    As I wasn't comfortable soldering the wires from the amplifier to the antenna contact points on the window, I used a conductive paint, which I found really good to use. It's called bare conductive and came in a squeezy tube.
    I did a scan today and I still have a couple of fault codes.
    2 Faults Found:
    02877 - Digital Radio Antenna (R183)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 176566 km
    Time Indication: 0
    Date: 2016.09.24
    Time: 17:01:05
    Freeze Frame:
    Voltage: 11.40 V
    03175 - Invalid Data Set
    000 - -
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 222
    Mileage: 176566 km
    Time Indication: 0
    Date: 2016.09.24
    Time: 17:00:55
    Freeze Frame:
    Voltage: 11.40 V
    Bin. Bits: 00000000 00001110
    I have cabled between the amp and antenna as detailed in this thread - VW Audi Forum - The #1 VW Group Community
    If I clear the codes and check again the codes return. Has anybody else seen this?
    Thanks,
  1. Audi A4 3.0 TDI Quattro 245ps Special Edition (Brakes Upgrade)
    By Grouto in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-11-2014, 08:28 PM
  2. Newbie and new owner of a Avant 2.0T FSI S line Quattro special edition.
    By Quattrorob in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-06-2014, 03:25 PM
  3. Audi a6 1.9 tdi avant 130 special edition. What is so special?
    By Ganch in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-02-2013, 09:18 PM
  4. Mud Flaps - 2011 A6 Avant S Line Special Edition (2.0tdi 170) ?
    By Mexico in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-07-2011, 09:45 PM
