Thread: door open sign on dash but is closed!
  1. door open sign on dash but is closed!
    I've a 2000 gttdi 115 and the door open indicator on the dash stays lit and interior lights now stay on. I've checked all the doors are shut and it is the drivers door that's causing the problem.
    I thought it must be an iffy connection but on looking for the traditional 'plunger' that's linked to the interior light that gets depressed when the door is shut there isnt one. I wondered if anyone knows how the system works or am I probably looking at damp/water in the locking system?
  2. Re: door open sign on dash but is closed!
    Norfolk
    The plunger is now a microswitch built into the lock. If you are up for it, you can strip it out and have a look. Sometimes it's fixable, sometimes not. Then you need a new lock.
  3. Re: door open sign on dash but is closed!
    Southampton, UK.
    See this thread to help fix the problem: https://www.vwaudiforum.co.uk/forum/s...ad.php?t=76297
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  4. Re: door open sign on dash but is closed!
    Aug 2008
    Hereford
    Its fiddly to replace you arm needs to bend like a 'Z'
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. Sticky Dash - Armor Oil Blames VW plastics
    By felixoscar in forum Golf MK4 - 1999 - 2004
    Last Post: 15-09-2009, 11:09 PM
  3. Dash problems...still....gremlins, connectors what and where
    By 1.9 TDI Sharan in forum Touran - Sharan - Caravelle
    Last Post: 02-01-2008, 04:29 PM
  4. Flashing Sign on Dash
    By eskimo in forum Golf MK3 - 1993 - 1999
    Last Post: 10-12-2007, 08:21 PM
  5. beep from dash when ignition is turned on
    By johno in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-05-2007, 06:45 PM
