Thread: Door light switch? GT TDI PD 130
Results 1 to 9 of 9
  1. Door light switch? GT TDI PD 130
    Jun 2009
    Manchester/Cambridge
    Fixing all the little things whilst I wait to figure out parts numbers for alternator pulley failure.
    My driver side door switch doesn't seem to be working. It stopped working about 2 years ago in a similar manner, but then decided to start working again shortly after. Now since it's back with new turbo, it's stopped working again. Passenger side is ok, (3 door) and light comes on when you open door, but doesn't work when you open driver side door, interior lights and red warning light at bottom of inside door are not working.
    Is this a failed door switch? How do I fix and what part do I need.
    Many thanks.
  2. Re: Door light switch? GT TDI PD 130
    Southampton, UK.
    Sounds like a failed door switch - either a broken micro switch or a badly soldered joint. There was a howto somewhere on where to locate the joint. Try a search. If I come across it, will post it up here. Worth trying that out before buying a new door lock.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  3. Re: Door light switch? GT TDI PD 130
    Dec 2007
    Why , oh why can't VW put good locks on the cars they produce.
    this should help http://forums.vwvortex.com/zerothread?id=1542461
  4. Re: Door light switch? GT TDI PD 130
    Southampton, UK.
    Quote Originally Posted by Dave B View Post
    That was the exact link I was looking for!
  5. Re: Door light switch? GT TDI PD 130
    134 Post(s)
    2022 Post(s)
    What is wrong with VW door locks? They are very reliable in my opinion.
  6. Re: Door light switch? GT TDI PD 130
    Jun 2009
    My lock is fine, it's only the door light opening function that's not working. Will attempt to open up door mechanism at weekend, see if any solders broken, does look quite involved, so will try liberal WD 40 application first just incase it decides to start working again.
  7. Re: Door light switch? GT TDI PD 130
    Does the vehicle have central locking?
  8. Re: Door light switch? GT TDI PD 130
    Jun 2009
    It's a 3 door GT, so yes does have central locking. Locking/unlocking seems to be fine, just door light not working, so maybe problem 4th micro sensor in mechanical part.
  9. Re: Door light switch? GT TDI PD 130
    Jun 2009
    It's also late 2002, and reading some of the links above, other microswitches should be fine as this part was redesigned in 2001 on models.
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  3. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  4. Replies: 0
  5. Will a 54 plate tdi 130 turbo fit a 51 plate 130 tdi???????????
    By wasabi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-06-2007, 05:27 PM
