Thread: inlet manifold flap position sensor (bank1) P2015 00
Results 1 to 9 of 9
  1. inlet manifold flap position sensor (bank1) P2015 00
    Apr 2015
    had VCDS full scan as EML light keeps appearing.
    1 Fault FOund:
    7859 - Intake Manifold Flap Position Sensor (Bank1)
    P2015 00 [175] - Implausible Signal
    MIL ON - Confirmed
    see below.
    What's the resolution?
    Chet
    Audi Q5 2014 2.0 TDi Quattro
  2. Re: inlet manifold flap position sensor (bank1) P2015 00
    Nov 2012
    Somerset UK
    Wasn't this the same issue as your thread here:?
    p2015 - intake flap position motor
  3. Re: inlet manifold flap position sensor (bank1) P2015 00
    Apr 2015
    yes it is, but the 2.0 doesn't seem to have a swirl flap repair kit like the 3.0 does!
    Chet
  4. Re: inlet manifold flap position sensor (bank1) P2015 00
    Jul 2013
    77 Post(s)
    You will have to replace the intake complete, £400 from TPS on a good day.
    Try taking it off and giving a good clean this will take you around 3 hrs to do 1 hr removal, 1 hr clean and the 1 hr refitting.
    if you don't have the instructions then pm me you email and i will send to you.
    After the cleaning process this may not fix it.
    What i did was buy a new intake manifold, then replace it this took 2 hrs work. I then cleaned up the old one at my leisure, this way the car was still on the road.
    Mine flagged at around 40,000 miles, the new one has been on the car since then and has not done a thing and i'm at 103,000 now mostly Motorway miles.
    Short trips most likely make this happen more often.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  5. Re: inlet manifold flap position sensor (bank1) P2015 00
    Apr 2015
    Cheers Dan
    have PM'd u..
    Chet
  6. Re: inlet manifold flap position sensor (bank1) P2015 00
    Jul 2013
    77 Post(s)
    check your inbox
    Dan
  7. Re: inlet manifold flap position sensor (bank1) P2015 00
    Apr 2015
    Thanks DAN for the instructions on the intake clean.
    Has worked so far for 5days - no engine light.
    cleaned out lots of carbon and swirl flaps were dirty.
    new gaskets installed, egr cleaned too.
    much better response on the car.
    cheers bud/
    Chet
    2 2 0
  8. Re: inlet manifold flap position sensor (bank1) P2015 00
    Dec 2007
    Quote Originally Posted by dan2485 View Post
    Sorry to bump an old thread, but this is the exact problem our 140 A3 currently has. Any idea if the intake manifold flap motor is available separately?
  9. Re: inlet manifold flap position sensor (bank1) P2015 00
    Jul 2013
    77 Post(s)
    I think that you can get the motors seperately but this will only fix half of the problem.
    What engine code do you have?
    As there are different types of flaps/motors i.e. a flap rail in the intake with muliple flaps or a single flap/motor part.
    Whats most likely happened is that you have had a build up of carbon and this has prevented the flaps from opening or closing, then the motor will struggle and possibly strip the plastic cogs in the motor.
    If caught early enough then the clean maybe good enough.
    Dan
  1. p2015 - intake flap position motor
    By climbachia in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-08-2015, 10:49 PM
  2. Replies: 1
    Last Post: 07-04-2015, 11:02 PM
  3. Replies: 1
    Last Post: 19-05-2014, 01:05 PM
  4. 7156 - Intake Manifold Flap Position Sensor (Bank 1) P2015 00 [039]
    By gtx2010 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 19-01-2014, 11:53 AM
  5. Intake Manifold Flap Position Sensor (Bank 1)
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-03-2013, 02:48 PM
