Thread: p2015 - intake flap position motor
  1. p2015 - intake flap position motor
    Apr 2015
    hi
    I am getting engine management light - and after a code scan - shows as =Intake manifold flap position motor.
    what are my options for this pls? - quick google shows people having to replace the whole manifold ? ££££££
    thank you.
    Chet.
  2. Re: p2015 - intake flap position motor
    Oct 2014
    Bristol
    Assuming it's the normal problem, you can get repair kits on eBay for £60 last time I looked.
    Set comes with flaps, bushes, end piece, link rod and clip.
    You can buy the link rod/clip separately for £12, and do with no real dismantling. Might fix it for a while, but the problem comes because the sticky flaps wear the linkage. The above, and a bit of cleaning, is the proper fix.
    If it's a motor problem, you can get these too, but they cost more than a set of flaps.
    A6 2005 3.0 TDI Quattro Tiptronic - Only mod so far = Integrated DAB
    Octavia 1 2005 1.8 20v VRS - Rescue Project !
  3. Re: p2015 - intake flap position motor
    Apr 2015
    hi thanks for the info.
    any links for the repair kit on ebay pls?
  4. Re: p2015 - intake flap position motor
    Nov 2012
    Somerset UK
    Get it from your local Audi dealer, if you are in the UK this will be cheaper than Ebay, as both sides (in the case of 2.7 or 3.0 diesel engined cars) is around £14
    I did not have your fault but an 'intake manifold runner - lower stop not reached' fault and have driven with this for almost 2yrs with no adverse affects to driveability, economy or emissions
    It would be useful if you added your model year and engne size to your signature strip...as both Edwards and I have?
  5. Re: p2015 - intake flap position motor
    Apr 2015
    thanks MarkTM
    updated as requested.
    What kit do I ask for at the dealer?
    Chet
    Audi Q5 2014 2.0 TDi Quattro
  6. Re: p2015 - intake flap position motor
    Nov 2012
    Somerset UK
    Swirl flap repair kit.
    I know it applies to the 2.7 and 3.0 which use 2, possibly the 2.0 just uses one...but am sure someone will be along to tell me that the 2.0 doesn't have one!
  7. Re: p2015 - intake flap position motor
    Dublin, Ireland
    Need to check it but think I have this.. shows up as an intermittent engine management warning but no other symptoms and will often just go out on next start. Been happening for 6 months+ without any obvious effects
    Was quoted 700 EUR to fix so this would be great news!
  1. Cold/first start issue - egr position (Act) intake flap always shows 94.5 % ?
    By sparkymarky in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-08-2014, 02:53 PM
  2. 7156 - Intake Manifold Flap Position Sensor (Bank 1) P2015 00 [039]
    By gtx2010 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 19-01-2014, 11:53 AM
  3. Intake Manifold Flap Position Sensor (Bank 1)
    By gdallas in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-03-2013, 02:48 PM
  4. Motor for intake manifold flap
    By stephen k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 05:47 PM
  5. Particle Regulator Motor/Position Flap Motor
    By Faye93x in forum Audi A3 - Archive Topics
    Last Post: 30-03-2009, 02:02 PM
