Thread: touran aux heater
Results 1 to 10 of 12
  1. touran aux heater
    Dec 2013
    tamworth england
    Hi all.
    Does anyone know an easy way of replacing the auxiliary heater or does the dash have to come out. Have had 5 fault codes come up;
    01411 temp sensor- short to ground
    01415 recirculating pump- open or short to plus
    00664 fuel gauge- lower limit exceeded
    02251 heater unit locked
    01444 under-voltage shut-off (automatic)
    This may be a silly question, but is it serviceable or fixable without removal.
    Any help appreciated.
  2. Re: touran aux heater
    Mar 2009
    Worcestershire
    Get your codes read by someone with VCDS cable or a garage with Autologic, its possible to reactivate the aux heater
  3. Re: touran aux heater
    Dec 2013
    tamworth england
    Hi b1ackb1rd.
    Thanks for your response. The codes were read with a vcds cable, I just didn't write down everything that came up, I just wrote down the fault code themselves and the description, sorry. I do have the print out so I can write it all out when I get home if that will be any more help.
    I didn't know it could be reactivated or I would have tried at the time of reading. I'm not the one that owns the cable so I won't be able to get it done just yet.
  4. Re: touran aux heater
    Jun 2010
    London
    When found in Aux Heater module of VW Touran (1T, and similar models), unlock heater module by saving a 1 in Adaptation Channel 042, then clear fault codes.
    avoid fuel light to come on the dash, low fuel locks the aux heater.
  5. Re: touran aux heater
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Auxy heater is behind front offside bumper next to screen wash bottle, from the codes posted it looks like the circ pump needs replacing, not sure about the temp sensor short. I think pump can be replaced without removing the whole unit but access is tight. These things are a pita but helpful inthis weather. Mines knackered as well but cant face working on it in sub zero driveway.
  6. Re: touran aux heater
    Dec 2013
    tamworth england
    Thanks for that, I'll have a look tomorrow and see. Might have to put up with it for a bit though, don't mind the cold too much lol.
  7. Re: touran aux heater
    Jun 2010
    London
    have a look at this page
    VW Touran Webasto Thermo Top V Water pump renewal | Lausdahl.com
    TPS wants 90£ for a new pump.
  8. Re: touran aux heater
    Dec 2013
    tamworth england
    Thanks for that link willuk.
    I had that fault code come up on vcds. So pretty likely the pump is shot. Will have to do some shopping around, already spent quite a bit on the car recently, and not even luxuries. ��
  9. Re: touran aux heater
    Nov 2020
    Scotland
    The replacement of the pump is fairly simple to anyone that might come across this old post here is a video
    Touran Webasto Fault 01415 Recirculating Pump V55 Replacement and Heater Unlock with VCDS - YouTube
  10. Re: touran aux heater
    Mar 2017
    Hampshire UK
    I'm having to find a new garage after my regular guy retired. So went to a local 'VW Specialist', and asked how much it would be to reset the Webasto on my Touran. 'Dunno what you're talkin' about. What's a web... what??? Diagnostic is £40 mate.'
    Cross that one off then.
    1 person in 10 understands binary, the other one doesn't.
  1. aux heater
    By s7gpt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-11-2012, 06:10 PM
  2. Great heater performance, does my B6 have an aux heater fitted?
    By andrewturner in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 13-11-2011, 12:38 AM
  3. aux heater help
    By kirkyboy in forum Touran - Sharan - Caravelle
    Last Post: 25-03-2010, 08:57 AM
  4. Question Aux Heater
    By Kj5cott in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-01-2009, 04:10 PM
  5. AUX, where in a touran?
    By ozkanb in forum Touran - Sharan - Caravelle
    Last Post: 25-06-2007, 02:59 PM
