Re: Disable motion sensor?
Quote:
Originally Posted by
AT.
Probably you can try the following: Disable the Safelock.
To do this, you have to press the "lock" button on the remote two times in less then 2 seconds. In this case, the Safelock will be deactivated, and by this, hopefully the towaway monitoring and the motion sensors will be disabled until the next open/close session.
Thank you, that seemed to do the trick, no alarms registered on the way back. :-)
Also meant to say, if anyone has air suspension, there’s also a setting in the MMI to stop is self-levelling whilst on a ferry etc
