1 Attachment(s)
Help with identifying part
Hello there,
Can someone help me identify part in picture and suggest remedy!!
The engine cover on my 01 passat tdi came loose and from vibration and friction sheared a hole in the bend pictured.so im leaking deisel. is it the case that i can just replace the bend thats damaged or is the whole unit buggered??
While im here i may as well ask if anyone knows where i could pick up a replacement engine cover?
Re: Help with identifying part
Can you give me the part number off the label? or what looks like a part number from the picture...
I will then see if I can find what it is.
Quote:
Originally Posted by
devereux
Hello there,
The engine cover on my 01 Passat tdi came loose and from vibration and friction sheared a hole in the bend pictured.so I'm leaking diesel. is it the case that I can just replace the bend that's damaged or is the whole unit buggered??
While I'm here I may as well ask if anyone knows where I could pick up a replacement engine cover?
Unless I'm very much mistaken, that's the union to the fuel filter, whether you can pick the union up separately I don't know.
Engine covers, probably a scrappers is the best bet.
HTH
cheers Stuart ,
in work at the moment but will post the number on the label this evening
devereux
Hello there,
I believe that is a fuel cooler. I looked at mine, it appears that the pipe is welded to it. It may be possible to braze or solder the pipe to repair the hole.
Hello, it's the bend thats attached to the fuel filter. Filter is about £23 from main dealer. For the engine cover iv'e seen them on ebay.
saintsman
It's not the fuel filter! The part in the photo is attached to the filter by the bolt in the centre. The filter itself has no pipes attached to it!
As stonedagain says, that is the fuel cooler heat exchanger.
stuart
The part number is 3B0 201 896
Thanks to all
3B0 201 896 is not available as a spare part, you have to buy assembly 3B0 127 400 C which is £160.
