Does anyone know any of the following torque settings for a 2006 B6 Passat?
main front hub bolt
inner CV joint flange bolts
front brake calliper pins
front brake calliper bracket bolts
bottom ball joint nuts
upper tie rod nut
Printable View
main front hub bolt
upper tie rod nut
Main hub bolt. Hex bolt...200Nm + 180 degree 12 point bolt...70Nm + 90 degree..Use new bolt.
CV joint/gearbox bolts M8 spline...40Nm (10Nm at a time) M10 spline 70 Nm (ditto)
Bottom ball joint nuts....60Nm
Caliper Pin....30 Nm
Caliper bracket....190 Nm
Tie rod ? Do you mean track rod ? which is 100Nm ( tighten loosen 180 degree retighten)
@martin1810 : Thanks for all the torque settings :beerchug:
Regarding the main hub bolt which is a 22mm (I think) hex on mine ... I believe that this should *not* be reused but when checking with a main dealer parts dept, they only had the 12 point star bolt listed. Does anyone know if the 2x bolts have the same thread? i.e. can the be interchanged?
