Re: Unable to get any gears
Pressure plate broken theeths. You will need a new clutch kit. Have a look underneath for broken linkage if no sign of it, then is the clutc pressure plate. Are the brakes ok ?
More likely the drivshaft stripped it's splines. I can't remember which one it is that goes. It's quite well known on the T5. Ask the dealer if they will do a goodwill claim.
The bit that strips is not at either end, it's like a two piece shaft and the bit that goes is three quarters of the way along.
My daughter's T5 174bhp/6-speed did same thing on Saturday evening. Moved off, bang, no drive. Gear selector engages in gate fine just no drive.
Of course no idea where the towing eye was....:zx11:...so looped rope round front suspension for a slow 400 yard tow home.
It's gone to her local garage now, will report back.
Hi I have seen this happen a couple of times and it was the right gearbox stub shaft which had stripped its splines
So is that new drive shaft or what? Sorry but no knowledge of Vdub bits as I am actiually a Volvo man :( but looking for solutions to my daughter's problems.
I do actually have a little bit of Vdub bits in that the rear brake calipers on my Westfield are from a Golf!!! :o
If it is as i suspect you will need a new stub shaft,and a new drive shaft
Reported as new drive shaft, not sure which side, my daughter didn't ask. Repair with part is about £550 inc VAT. For info, car is coming up 5 years old, done 86k and always been used as domestic rather than commercial.
Is it likely the other side will go bang too?
Oh! And thanks for f/b.
Hi It has only been the right side so far.The left and right consruction is a bit different
That's some comfort, thanks.
I guess that the system is asymetric in common with many vehicles' installation.
